70 RR Air Grabber troubleshooting
#2737434
01/28/20 02:29 PM
01/28/20 02:29 PM
Posts: 2,087 New Mexico
JMCFAN
New Mexico
No response from switch at all
New coil... old original switch
Hooked up vacuum line to intake and tested at actuator... opens and closes fine
Switch....? YO or Classic Indus....??
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: 70 RR Air Grabber troubleshooting
[Re: JMCFAN]
#2737452
01/28/20 03:52 PM
01/28/20 03:52 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
I would listen for a vacuum leak with a stethoscope before doing anything else.
I once made my own switch, using parts for an industrial control vacuum system. There was no good source for good switches then. I bought one and it was cheaply made and I broke it somehow. The next time I used a big brass block of a switch up under the dash.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: Bob Stinson]
#2737454
01/28/20 04:14 PM
01/28/20 04:14 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I would suspect the solenoid (even if new) over the switch. have you tried to bypass it leaving the switch in place.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2737459
01/28/20 04:30 PM
01/28/20 04:30 PM
JMCFAN
New Mexico
No.... Will do that before I order a switch What should I expect.... ? Open and stay open....?
[Re: JMCFAN]
#2737464
01/28/20 04:42 PM
01/28/20 04:42 PM
70gtx440dana
Lansing, MI
No.... Will do that before I order a switch What should I expect.... ? Open and stay open....? Yes.....pretty sure the door will open and "stay open" after you shut off the engine. It will likely close after a little while versus immediate close with solenoid in place.
[Re: 70gtx440dana]
#2737466
01/28/20 04:46 PM
01/28/20 04:46 PM
JMCFAN
New Mexico
No.... Will do that before I order a switch What should I expect.... ? Open and stay open....? Yes.....pretty sure the door will open and "stay open" after you shut off the engine. It will likely close after a little while versus immediate close with solenoid in place. Thanks! So just pull the lines off the solenoid..and connect them together right... with a vacuum fitting...?
