Wilwood M/C - prop. valve for A-body? #2736995
01/27/20 09:15 AM
01/27/20 09:15 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Running the Stock '73-'73 A body front disc brakes and converting the rears to the Disc brake kit from The right stuff on my '72 Demon,
Looking at a Wilwood M/C - prop valve (Looks like good quality)
What bore size for 4 wheel disc manual brakes, and what prop. valve?
Thanks all!
Wally.
Re: Wilwood M/C - prop. valve for A-body? [Re: wkroncke17] #2737473
01/28/20 05:10 PM
01/28/20 05:10 PM
Wisconsin
Wisconsin
Nobody use Wilwood??
Any alternatives?
Re: Wilwood M/C - prop. valve for A-body? [Re: wkroncke17] #2737475
01/28/20 05:18 PM
01/28/20 05:18 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 68 Dart was originally 4-wheel drums. I'm converting to 4-wheel disc. From what I've read, you don't really have to have a prop valve. You can use a stock 4-wheel drum distribution block. I'll be using Dr Diff's 15/16" master cylinder with the adapter.
Re: Wilwood M/C - prop. valve for A-body? [Re: wkroncke17] #2737521
01/28/20 08:42 PM
01/28/20 08:42 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Which MC bore you use is going to be dependent on your caliper set up. I have 6-piston and 4-piston Wilwood calipers and run a manual 15/16" MC. The 7/8" was a little too much pedal stroke.
The prop valve I use is Wilwoods as well and comes with pre-bent lines. Check you have fenderwell clearance.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Wilwood M/C - prop. valve for A-body? [Re: GoodysGotaCuda] #2737910
01/29/20 10:47 PM
01/29/20 10:47 PM
Wisconsin
Wisconsin
That’s the setup I was looking into, damn that sure looks nice.
Will probably go with the 15/16” bore.
Thanks Goody!
