1996 neon charging questionthat to me has a strange #2736544
01/25/20 03:54 PM
01/25/20 03:54 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
I have a 96 neon with a charging problem . I can start the car let it warm up its fine <drive down the road the battery lights up on the dash . if I pull over shut the car off the battery light goes out when I restart it. then its fine then eventualy the light comes on and I have to stop it again then its fine.It doesn't seem to care if the heater and headlights are on or not .
Re: 1996 neon charging questionthat to me has a strange [Re: 3wracing] #2736554
01/25/20 04:31 PM
01/25/20 04:31 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
take a hand held volt meter with you and when light comes on, test voltage at batt. record it. shut eng off, restart and if light off, check voltage with eng running. comparw 2 readings. repost results bet u have bad alt.
Re: 1996 neon charging questionthat to me has a strange [Re: rbkt65] #2736694
01/26/20 01:55 AM
01/26/20 01:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree to check the voltage when it does it and see if it is charging. Also the PCM may have a code in it that may help. It can store coded like "Alt rotor open or short" and so on. It sounds intermittent and from what I remember the PCM controls the regulation on it. Could be an alt brush problem or even a PCM problem but the PCM controls the alt/bat lite so it don't sound like a PCM problem. Good luck , Ron
Re: 1996 neon charging questionthat to me has a strange [Re: 383man] #2736757
01/26/20 12:40 PM
01/26/20 12:40 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
Checked it a while ago it did have a code stored in it #47 low alternator output and low voltage on battery.
Re: 1996 neon charging questionthat to me has a strange [Re: 3wracing] #2736767
01/26/20 01:14 PM
01/26/20 01:14 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
#47 isn't a valid code on an OBDII system.
PXXXX with the X's being numbers is how the code will be formatted.
Once you find out the P code you can use this site
https://www.obd-codes.com/trouble_codes/
for generic pointers as to where to start looking.
Re: 1996 neon charging questionthat to me has a strange [Re: Sniper] #2736774
01/26/20 01:47 PM
01/26/20 01:47 PM
Andrewh Offline
Andrewh  Offline
I would pull the alt and have it tested on its own.
it could be bad, or the ecm could have a problem for charging.
If the alt checks out good, I would wiring in an old stand alone vr and call it good. Common fix. rather than spending a couple hundred on a new ecm just for charging.
Re: 1996 neon charging questionthat to me has a strange [Re: Andrewh] #2736777
01/26/20 01:55 PM
01/26/20 01:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Pulling the alternator out of a 96 Neon is a real PITA.
Read the codes, troubleshoot, then pull parts.
Re: 1996 neon charging questionthat to me has a strange [Re: 3wracing] #2736795
01/26/20 02:35 PM
01/26/20 02:35 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Start the engine and disconnect both sides of the battery and see what happens. Those are not alternators, they are AC generators.
Re: 1996 neon charging questionthat to me has a strange [Re: Sniper] #2736810
01/26/20 03:13 PM
01/26/20 03:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
For sure.
FYI,,, I think the early Neons have a battery temp sensor on them.
If its not plugged in the alternator does not change ,,,I found this out the hard way
Re: 1996 neon charging questionthat to me has a strange [Re: gtx6970] #2736814
01/26/20 03:24 PM
01/26/20 03:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Check the splice near the battery on the 10 gauge? red wire. As I remember its encapsulated in a piece of white or grey nylon near the battery.
Doug
Re: 1996 neon charging questionthat to me has a strange [Re: rbkt65] #2736879
01/26/20 08:02 PM
01/26/20 08:02 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
You have to catch this one while it's failing. having it tested may not show a problem as the unit isn't warm enough. And per the others it's regulated by the ECM so now there is two possibilities, 3rd is the 10 ga splice mentioned,4th could be a battery cable / connection problem or could be a ground issue. going to have to troubleshoot it or throw parts at it till you get lucky frown twocents beer
Re: 1996 neon charging questionthat to me has a strange [Re: 71birdJ68] #2736997
01/27/20 09:21 AM
01/27/20 09:21 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Do not pull wires off when running,it may spike voltage&kill the computer.voltage regulator is built into the computer.My bet is the alt.
Re: 1996 neon charging questionthat to me has a strange [Re: GarageDodge] #2737153
01/27/20 05:12 PM
01/27/20 05:12 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
If it's the original Alternator, it needs to be changed..then move forward
Re: 1996 neon charging questionthat to me has a strange [Re: AARCONV] #2737211
01/27/20 07:32 PM
01/27/20 07:32 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
thanks for all the help guys in a strange twist drove it to work today ran fine their and back? I don't have a clue the car has about 60000 miles on it .we will see
Re: 1996 neon charging questionthat to me has a strange [Re: 3wracing] #2737280
01/27/20 10:33 PM
01/27/20 10:33 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Sounds more like an intermittent connection the wiring somewhere.
