Re: 1996 neon charging questionthat to me has a strange
[Re: 3wracing]
#2736767
01/26/20 01:14 PM
01/26/20 01:14 PM
Posts: 6,288 nowhere
Sniper
nowhere
#47 isn't a valid code on an OBDII system. PXXXX with the X's being numbers is how the code will be formatted. Once you find out the P code you can use this site https://www.obd-codes.com/trouble_codes/for generic pointers as to where to start looking.
[Re: Sniper]
#2736810
01/26/20 03:13 PM
01/26/20 03:13 PM
Posts: 21,443 It's a dry heat
gtx6970
It's a dry heat
Pulling the alternator out of a 96 Neon is a real PITA.
Read the codes, troubleshoot, then pull parts.
For sure. FYI,,, I think the early Neons have a battery temp sensor on them. If its not plugged in the alternator does not change ,,,I found this out the hard way
[Re: rbkt65]
#2736879
01/26/20 08:02 PM
01/26/20 08:02 PM
Posts: 15,418 Omaha Ne
TJP
Omaha Ne
