Small Block Solid Roller Cam Rocker Arm Recommendations #2736528
01/25/20 03:18 PM
01/25/20 03:18 PM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Need recommendations on rocker brands.
Small Block
Trick Flow Heads with a .680 solid roller cam.
What brand rockers do you guys like with solid roller spring pressure's?
Also, if you have any for sale 1.6 ratio inbox me details and price.
Thanks.
Re: Small Block Solid Roller Cam Rocker Arm Recommendations [Re: DaKuda] #2736567
01/25/20 04:56 PM
01/25/20 04:56 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would run nothing but T&D paired shaft rockers. They may require machining the heads to except the rocker arm stand.
There are not cheap but it is the only way to go with big spring pressure.
