300C/Magnum advice #2735881
01/23/20 04:51 PM
01/23/20 04:51 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
Have been looking for some time now at buying either a 300C STW or Dodge Magnum from about 2005-2008 all of them in my pricerange has 100.000-150.000 miles on them and i would love to own one with a hemi but have also looked at the 3.0 diesel and the 3.5L V6,the only engine that i have ruled out entirely is the 2.7.
Any advice on what to look for specificly on these cars,am i stupid for comsider one with that kind of milage?
I understand that a well taken care of car with more miles will be better than something that has been treated as garbage for half the distance but i dont know much about known trouble with these cars and such.
Moving to a house out on the country side pretty soon so will drive it quite some miles daily to work and such and would love to own one of them cars.
Re: 300C/Magnum advice [Re: 1Fast340] #2735890
01/23/20 05:33 PM
01/23/20 05:33 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Front lower control arm bushings are junk, and used to only be available with the control arm. Not sure if they are sold separately now or not. If not, the control arms themselves are pricey (about $200 each for RWD, $400 each or AWD).
Earning every penny of that moderator paycheck.
DBAP
Re: 300C/Magnum advice [Re: 1Fast340] #2735897
01/23/20 05:59 PM
01/23/20 05:59 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I have owned a 05 Magnum RT since it had 50k mi on it. It now has 135k miles on it and best car I have owned...ever! (daily diver). I had a wheel brg at 90K, front ball joint that needed replacing at 100K so I replaced everything (both lowers and upper on each side), air bag recall, O2 sensor, heater blower motor at 130K... are the only non maintenance (if you want to look at it that way) parts I have replaced on it.
As I said I love mine and I am considering getting a low mileage SRT8 version.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 300C/Magnum advice [Re: W.I.N. Racing] #2735908
01/23/20 07:21 PM
01/23/20 07:21 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Relative had a V6 Charger and it ate front tires more than normal in my opinion. Also started to consume oil when it crossed 100k so they traded it in for a newer one.
Someone on here posted that the front frame rails can rust sway depending on where the car was driven.
Re: 300C/Magnum advice [Re: Neil] #2735909
01/23/20 07:30 PM
01/23/20 07:30 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I've had several Chargers with 5.7 and worked with 3.5's and 5.7's. The 3.5's have actually been amazing workhorses!!!!! Just keep on going and going!!!! Too bad the Magnums went out of production prior to '09 when Eagle Heads came out on 5.7's. But if you find one that sounds good and runs good, you're probably fine. Just keep up maintenance with proper oil.
Yes, front end problems, but not on my personally owned ones. The Police ones that are subjected to what I'll call abusive driving do suffer tension strut failures, along with control arm bushings. So you may have to replace them once, but if you don't drive on really bad roads, and aren't rough on it, it won't be worse than other cars. twocents
Facts are stubborn things.
Re: 300C/Magnum advice [Re: larrymopar360] #2735928
01/23/20 08:48 PM
01/23/20 08:48 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I wish they would have offered the diesel over here !! I have a 06 magnum rt awd. Owned it since new, and now has 219k km (136k miles). I have always changed oil & filter at 5k km. Complete brake job @ 150k km, put larger police rotors on rear (makes a difference), shocks changed at 210k km - same time only needed one lower control arm (c/w ball joint & bushings), transmission service at 100k km. Transmission interlock replacement last fall (it is inside the shift mechanism - relatively easy to replace. And replacement part is anodized aluminum, not plastic - no way this replacement will break), differential service (frt & rear) . . . over all, I love this car. If I had to ONLY have one car, this would be it. Love the AWD in winter, 5.7 hemi still gives me a smile after all this time !!! . . . as usual, would suggest paying a bit more for a car that you find, that is in great shape !! . . . LX forum is good place to get lots of information on these cars.
Good luck !
Re: 300C/Magnum advice [Re: 1Fast340] #2735969
01/23/20 11:24 PM
01/23/20 11:24 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Have you thought about looking at the insurance pools? There are 65 Magnums listed nationwide in Coparts system. Here's one:
https://www.copart.com/lot/51701589
Master, again and still
Re: 300C/Magnum advice [Re: DaveRS23] #2736040
01/24/20 09:45 AM
01/24/20 09:45 AM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
I was recently shopping Magnums and came across a real rarity: 2008 R/T on ebay. Has the 1-year only styling and something like under 700 built. May end up with one...someday.
Re: 300C/Magnum advice [Re: DaveRS23] #2736043
01/24/20 10:03 AM
01/24/20 10:03 AM
a12rag Offline
a12rag  Offline
The OP is in SWEDEN . . . so for him over there, probably different issue. Also, in Europe, they sold the 300 in "magnum" form (stn wagon) . . . and with 3.0 liter diesel !!
Re: 300C/Magnum advice [Re: a12rag] #2736136
01/24/20 01:55 PM
01/24/20 01:55 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I'm not sure that I understand your point. He's shopping this side of the pond isn't he? And didn't say that he wanted diesel only. So why would the insurance pools be a 'no-go' for him?
Re: 300C/Magnum advice [Re: 1Fast340] #2736200
01/24/20 04:41 PM
01/24/20 04:41 PM
(Central) PA
Runner2go Offline
Runner2go  Offline
(Central) PA
Being in Europe you have the best of both worlds available... the Chrysler 300c Wagon
The wife wanted a 300c wagon bad... but we weren't allowed to buy them in the US mad
And had to watch trailers of these heading down I83 to the Baltimore Harbor, to be shipped across the pond.
1966 383, 4-sp Charger 38yrs
1970 440+6, 4-sp Road Runner 36yrs
1974 360, auto Challenger 25yrs,in Family 41yrs
2003 Ram 2500 QCLB 4x4 Cummins HO
2010 5.7L R/T 6sp Challenger - Mopar10
2018 392 Daytona Charger
Re: 300C/Magnum advice [Re: Runner2go] #2736212
01/24/20 05:06 PM
01/24/20 05:06 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You could swap a 300 front clip to a Magnum. Supposed to be a bolt on swap.
Kevin
Re: 300C/Magnum advice [Re: Runner2go] #2736215
01/24/20 05:08 PM
01/24/20 05:08 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have driven a 2007 Magnum R/T since new. It has 177,000 miles, a lot of them easy road miles.
The only failures I have had is the ignition switch and a problem with the shifter. The shifter problem is very common and I think the Mopar part is an upgrade and I think there are even aftermarket parts that are even better. Both of these problems involved a ride on a tilt back.
It still has the original brakes which are still good, but I plan to replace soon.
I recently had a four wheel alignment as all the suspension parts are still fine.
I have taken good care of it.
Varying opinions on this but if one of these engines has been overheated I think they are vulnerable to dropping valve seats. My research has been minimal but I have never seen anyone that had dropped a valve seat that knew the car had never been overheated.
You probably have seen it but if not there is a Magnum Page on Facebook.
Before you I saw you were in Sweden the mention of Diesel got my attention!
I assume there are lots of all wheel drive models there. Not many in my part of the woods but I think the reliably of those is good.
I wish they still sold them new!
Re: 300C/Magnum advice [Re: 340Cuda] #2736299
01/24/20 09:07 PM
01/24/20 09:07 PM
a12rag Offline
a12rag  Offline
The original shifter interlock is made from plastic. At some point in time as it ages, the little hook of plastic that holds a spring, breaks and releases the spring and no shift ! The attached pic is the piece out of my car ! I was lucky it happened for me, while parked in my garage at home . . . did a google search, and then off to NAPA for the Dorman replacement part - made of Anodized aluminum - no breaking in the future !!, and took about 1 hr to pull apart and replace !! . . . the "white spot" on the pink part is where the little hook broke off . . . and yes, that is the actual color of the part !!! Again, you can get the shifter working, without changing it, but it's a "jury rig" kind of thing . . . best to google the issue !!!
Re: 300C/Magnum advice [Re: a12rag] #2736313
01/24/20 09:59 PM
01/24/20 09:59 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I had a 2005 Magnum for a while. Besides regular maintenance, I changed the headlight switch (headlights were flickering) and I believe it had a clockspring recall. It was mostly a solid car. I was one of the unlucky ones that had a valve seat drop in my hemi and it cooked the #1 cyl. While the engine could have overheated before I owned it (I don't know either way), it did not overhead in the 3 years I owned it so I was pretty surprised when it dropped. Anyway, it sounds like the pre-eagle head hemi is not on your list anyway. I really enjoyed driving that car. Tons of room and lots of space in the back with the rear seats folded forward. Comfortable on long rides. If they had kept making them I might have a 2019 Magnum in my garage instead of a Charger.
Re: 300C/Magnum advice [Re: a12rag] #2736314
01/24/20 09:59 PM
01/24/20 09:59 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
It's literally know as the "pink thingie" by most people that have had the problem. laugh2
When you google search pink thingie. https://www.google.com/search?q=pink+thingie&ie=utf-8&oe=utf-8&client=firefox-b-1
Re: 300C/Magnum advice [Re: Tom_440] #2736462
01/25/20 12:05 PM
01/25/20 12:05 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted by Tom_440
I If they had kept making them I might have a 2019 Magnum in my garage instead of a Charger.
If they made a 2020 Magnum with all the latest electronics I would have one on order!
Re: 300C/Magnum advice [Re: DaveRS23] #2736616
01/25/20 07:40 PM
01/25/20 07:40 PM
5thAve Offline
5thAve  Offline
Where does he say he's looking here, he's only looking for opinions and advice.
Re: 300C/Magnum advice [Re: 5thAve] #2736633
01/25/20 08:31 PM
01/25/20 08:31 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Just offering a suggestion. If it is out of line, everyone is welcome to ignore it.
Re: 300C/Magnum advice [Re: 1Fast340] #2736706
01/26/20 07:35 AM
01/26/20 07:35 AM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
Some good stuff here, i have been looking at the AWD versions aswell thats for sure but not sure i like how tall they sit compared to the RWD versions.
The 300s seems to have alitle more luxury in interiors but i somehow like the exterior look of the magnum better,decistions are hard to make.
And nope i have not ruled out a Hemi.,would actualy prefer one of those if one can be found at the right price that is not beat to death,but seems much easier to find a 3.5 or a 3.0 diesel in good shape. not in a rush yet i have a few weeks to get a car before moving to the house in the country side
