You need some more pictures to know what you have. If those calipers are radial mounts then you should be able to build a bracket kit that works. The Doctor Diff hubs are a good choice or buy a set of hubs from Baer. You will need to know what you're doing to get everything in the correct place so if you don't have experience building big brake kits you might want to consult with an experienced street rod fab guy. You'll need at least an 18 inch rim and maybe a 19 inch rim. Just depends on the shape of the calipers and the rim. The bolt pattern on those rotors will be wrong so you will need to redrill them to fit the hubs.
