Re: One companies modified tunnel ram for the street..$$
[Re: 67Satty]
#2735631
01/22/20 03:46 PM
01/22/20 03:46 PM
Posts: 9,038 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
but why do we need a new top for a tunnel ram? Did you not notice the lack of a common plenum ?
[Re: Stanton]
#2735636
01/22/20 04:05 PM
01/22/20 04:05 PM
Posts: 4,831 Holland MI Ottawa
2boltmain
Holland MI Ottawa
but why do we need a new top for a tunnel ram? Did you not notice the lack of a common plenum ? From what I did read evidently having dedicated plenums improves low end. All good but that price! Knocking on new six pack induction cost.
Keep old mopars alive.
[Re: 2boltmain]
#2735672
01/22/20 07:59 PM
01/22/20 07:59 PM
Posts: 43,741 Bend,OR USA
Cab_Burge
Individual runner tunnel rams where popular in Pro Stock for a short while in the 1970s on BB Chevy, Fords and Hemi motors This add is for SB Chevy, correct? Including two new carbs, linkage and new special cast aluminum IR manifold at the retail price is probably not a bad deal I've converted more than one in line dual quad set ups on both 360 degree intakes and dual plane intake to one to one linkage to make then run better, way better on the early hemi motors and wedge motors with the dual quad single plane intakes I've never ran or race a IR tunnel ram motor so no hands on experience in tuning them or driving them
[Re: 2boltmain]
#2735794
01/23/20 10:28 AM
01/23/20 10:28 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
That's really old, and only for SBC motors. As far as the Weiand tunnel rams, I've got 2 for a low deck- they look different externally, but the mis-match between the top and base is damn near the same, There's an article on HR ... We looked it over out-of-the-box and decided it needed porting. The runners neck down in height at about the midpoint from the cylinder-head side, then transition to a large cross-section "D" shape at the plenum. We performed considerable porting, carefully measuring the point of minimum cross-sectional area and removing metal in that area. Access to any part of the runners is wide open for porting, with the top plenum removed. Later, we found this note on the Weiand Hi Ram in a Mopar Performance race manual, "For best performance, the Weiand ram should be ported out to the size of the port in the head." Current link, since HR broke all the old ones The manifold shootout was on a 383, what's not clear is if that is the ported manifold Steve Dulcich used in the older build, or another one he picked up later.
