Re: Low Oil Pressure [Re: Stroker Scamp] #2575349
11/07/18 03:10 PM
11/07/18 03:10 PM
crabman173
crabman173
Kink in oil pressure line? While doing the headers? Copper or nylon easy to damage
Re: Low Oil Pressure [Re: Anonymous] #2696378
09/11/19 01:13 AM
09/11/19 01:13 AM
pacific northwest
Stroker Scamp Offline OP
pacific northwest
Part of the problem was a bad battery not spinning the engine as fast, oil pressure is good now with the new filter and new oil
I think might have had a stuck bypass? but we are all good now, just need to reset the valves. Hope this helps someone down the road
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Low Oil Pressure [Re: Stroker Scamp] #2734249
01/18/20 04:35 PM
01/18/20 04:35 PM
pacific northwest
pacific northwest
Want to update on this, still not happy with how long it takes to build pressure.
it takes over 30-40 seconds of cranking. It does build up but not like it use to.
So pulled the pan and took the pump out, opened the pump and it was clean inside
relief valve moves freely I can see oil up on the cam and pistons.
So I have pressure but why so long to build after no internal changes?
Thoughts and Thanks
Re: Low Oil Pressure [Re: Stroker Scamp] #2734253
01/18/20 04:53 PM
01/18/20 04:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Not sure what oil line you have to the gauge, but if its the small copper or nylon remove it and install the larger braided oil line. The gauge will respond much faster to cranking pressure and the blip of the throttle.
Re: Low Oil Pressure [Re: Stroker Scamp] #2734299
01/18/20 08:17 PM
01/18/20 08:17 PM
Cab_Burge Online work
Cab_Burge  Online Work
I won't EVER use the starter motor to build oil pressure, NEVER tsk
That is a old SB Chevy SOP, think about how many RPM the motor is spinning over on the starter and then how many when running work
Will the oil pump work better at 150 RPM or 600 RPM? work whistling
I also fill all my oil filters up completely (until they won't take any motor after soaking full many times scope up) with oil before mounting them on the motor, that way I don't have to worry about how long my motor will run with no oil pressure after changing the oil and filter work grin
Re: Low Oil Pressure [Re: Stroker Scamp] #2734538
01/19/20 04:31 PM
01/19/20 04:31 PM
Andrews,In. U.S.of A.
67_Satellite Offline
If you run the 1/8" plastic line, it is possible to restrict it by over tightening the compression fitting on either end. I once "dampened" an over active, jumpy gauge this way.Works but you have to sneak up on it.
Re: Low Oil Pressure [Re: Stroker Scamp] #2735077
01/20/20 09:54 PM
01/20/20 09:54 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
How fast does it build if you just start it?
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Low Oil Pressure [Re: racerhog] #2735303
01/21/20 03:21 PM
01/21/20 03:21 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
Hint....... I would stay away from cheap oil filters. Please use a wix racing oil filter.
Re: Low Oil Pressure [Re: johnzgarage] #2735310
01/21/20 03:37 PM
01/21/20 03:37 PM
The Wix racing oil filters bypass at least 20% more oil than their standard 51515 Ford, Mopar oil filters. I don't want trash being bypass into the motor tsk work
I use them,51515 filters now instead of the racing filters on everything I own except the race car that has a big remote mounted NASCAR type race filter up
Re: Low Oil Pressure [Re: Cab_Burge] #2735320
01/21/20 04:04 PM
01/21/20 04:04 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
You can say whatever you want to say about any brands of oil filter or use whatever you want, but ...... use a filter that can handle the psi in a effective manner.
Re: Low Oil Pressure [Re: johnzgarage] #2735390
01/21/20 07:44 PM
01/21/20 07:44 PM
Have you split open a oil filter?
I have puke years ago(1973 or 1974) on the first Hemi stocker we where racing in NHRA stock, 50W Valvoline oil and 20F outside air temp breaking in the cam in the drive way at 2000 RPM, bang it split down the center, what a mess down
As far as oil filters and bypassing, I like my motors to get clean oil, not with larger particle in it due to the filter bypassing 40% cold oil work
Re: Low Oil Pressure [Re: Stroker Scamp] #2735400
01/21/20 08:18 PM
01/21/20 08:18 PM
pacific northwest
pacific northwest
Thoughts and Thanks
When installing the
new hedders I had to raise the motor and looks like I dented the pan enough to have the pickup
make a witness mark on the bottom of the pan. Also had a thick layer of brown sludge where the pick
up sits (oil is Clean). Cleaned the pan and ready to put back together I hop it was just a combo of those 2.
No clue what the sludge was, not abrasive and no metal and yes I bent the pan back
Re: Low Oil Pressure [Re: Cab_Burge] #2735402
01/21/20 08:22 PM
01/21/20 08:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I
How do you measure the bypass quantity?
Re: Low Oil Pressure [Re: BSB67] #2735484
01/22/20 02:37 AM
01/22/20 02:37 AM
I
Wix has stated that their race filters with internal bypass bypass 200 % more(40% vs,20% than the stock filters do, they have also stated that their stock bypass filter can bypass up to 20 % with cold oil at the lower air temps, below 40F.
No rumors or I think I heard kind of information from me!
Re: Low Oil Pressure [Re: Cab_Burge] #2735496
01/22/20 07:52 AM
01/22/20 07:52 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I
Ok. You're not actually measuring, just using supplier literature. So the literature is saying that the valve is twice as big, so it can theoretically bypass twice as much. But in reality, it will only bypass the amount needed to control/balance the pressure differential dictated by the bypass relief. You will not actually know if, when, or how much oil is bypassed. Arguably, another good reason to not use a high volume oil pump and high viscosity oil.
Re: Low Oil Pressure [Re: 340Cuda] #2735702
01/22/20 10:42 PM
01/22/20 10:42 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
I had a similar evasive pressure problem. Car would have pressure then lose it. Prime it with a drill and great pressure. Long story short it was a cracked pickup tube that finally broke off at the block (rb motor)
Re: Low Oil Pressure [Re: Wirenut] #2735812
01/23/20 12:05 PM
01/23/20 12:05 PM
central il.
second 70 Offline
second 70  Offline
central il.
Same here except a hemi. Car would prime fine cold with a full pan of oil and be fine for quit awhile and hold 75psi until enough oil stayed in the top of the engine to get level below crack and would lose it's prime when the rpms were reduced.
