Re: Cam and crank sensors.
[Re: moparmitch]
#2735377
01/21/20 07:00 PM
01/21/20 07:00 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Mopar changed the sensors several times. I wish they would just stop doing that. i always ask to see the color of the o-ring on the sensor. that tells you what you need. I'll update the post later with what the colors mean. I'm on the road tuning today.
[Re: MattW]
#2736321
01/24/20 10:23 PM
01/24/20 10:23 PM
Posts: 935 Deland, Florida
biff426
Deland, Florida
I have both sets of sensors and I believe the eagle and the 6.4 use the same sensors. I have the old sensors in my 6.4 to use a FAST XIM in stand alone mode. I have not run it yet but the old sensors and new sensors are the same size physically. I have not run the old sensors on a 58 tooth wheel but I'm getting ready to see if it works real soon.
[Re: MattW]
#2741031
02/08/20 06:43 PM
02/08/20 06:43 PM
biff426
Deland, Florida
So I bought a pigtail for the 2009-2013 sensor and a 2009-2013 sensor. I spliced it in and the XIM saw the crank signal and fired up. Old sensor and new wheel will not work. And you need the sensor with the green Oring not the red oring with the 58 tooth wheel.
