Well I talked myself out of building one. To many other projects going on. This should be done in a few months.
I have this set up on my car as well. Been thru dragweek and won my class. With the cost of this set up don’t know why you would do it yourself. For what you see in pictures it is $1550. Tory Shellehamer makes them and you can find him on Facebook .
Looks like a great swap from the stock setup.
other than tubular uppers and strut bars to carry the weight of the coil holding the front up, what shock is needed? obviously a coil over type and I guess you can use your own length too
65lbs sounds great too !
