440 Piston ID
#2734610
01/19/20 07:11 PM
01/19/20 07:11 PM
Posts: 28 wv
73bbroadrunner
wv
Does anyone know who manufactures this piston? Thanks
Re: 440 Piston I.D.
[Re: mr_340]
#2734917
01/20/20 02:37 PM
01/20/20 02:37 PM
Posts: 4,711 Moved to N.E. Tennessee
GomangoCuda
X2. Trw/Speedpro. Mopar also sold them as D.C. or M.P. They give about 11.5 :1 compression with 906 heads. It's going to be a little more with most aluminum heads. I called Trw a looong time ago and asked about machining them to lower compression. They said I could safely take .090" out of the entire valve notch and the top of the dome. Don't try to take off the entire dome. Don't forget to round over the edges where you machine them. Rebalance as necessary.
Re: 440 Piston ID
[Re: R/T1968R/T]
#2734961
01/20/20 03:57 PM
01/20/20 03:57 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
One other note...... the valve pocket isn’t very generous.
If you plan of using a fairly long duration cam....... check the clearance.
Re: 440 Piston ID
[Re: fast68plymouth]
#2734977
01/20/20 04:32 PM
01/20/20 04:32 PM
GomangoCuda
If you plan of using a fairly long duration cam....... check the clearance. Yep, that was the primary reason I called Trw. I needed to know how much I could take out of the notch for a big flat tappet. They threw in the info about the dome.
Re: 440 Piston ID
[Re: GomangoCuda]
#2735115
01/20/20 11:59 PM
01/20/20 11:59 PM
Posts: 3,504 DFW
mr_340
DFW
I had one scanned and 3D printed 1/2 of the top. The notch area was about .240" thick and under the dome was around .40" at the thinnest part. I think if you take off the whole dome you would end up around 9.5:1 compression ratio unless you have small chambers.
Floyd Lippencott IV
