Shifter I'd #2734595
01/19/20 06:34 PM
01/19/20 06:34 PM
71ragtop Offline OP
71ragtop  Offline OP
Can anyone identify these shifters?
15794731283842928334207109643749.jpg15794731741619075678073877902145.jpg1579473199832566268022352504639.jpg1579473224330943864588818859621.jpg
Re: Shifter I'd [Re: 71ragtop] #2734747
01/20/20 03:23 AM
01/20/20 03:23 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Are there numbers on the reverse levers? I think that will help you ID them
Re: Shifter I'd [Re: 71ragtop] #2734749
01/20/20 03:38 AM
01/20/20 03:38 AM
Cab_Burge Online work
Cab_Burge  Online Work
They both look like Hurst brand for Mopar factory shifters found on the later NP833 O.D. trannies but I have not seen one made by Hurst that wasn't stamped with Hurst on the side of them confused shruggy
Re: Shifter I'd [Re: Cab_Burge] #2734825
01/20/20 11:01 AM
01/20/20 11:01 AM
New York
rarefish Offline
rarefish  Offline
New York
The top shifter in the second picture down looks like the 7180 Hurst shifter.
7180 should be stamped on the reverse lever.
They were used in the 1970-71 E-bodies and the early 71 B-bodies that had buckets.
Re: Shifter I'd [Re: rarefish] #2734847
01/20/20 11:54 AM
01/20/20 11:54 AM
71ragtop Offline OP
71ragtop  Offline OP
One has 2512 on the reverse lever and one has 7180 I also have one with a 6358 any idea what that's for? Thanks for your help.
Re: Shifter I'd [Re: 71ragtop] #2734911
01/20/20 02:17 PM
01/20/20 02:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
2336= '64-'65 A & B Body
6353= '68-'69 B Body,'68-up A body, '76-'80 F-body and truck/van with OD
7174= '70 only B Body
7180= '70-'74 E Body and '71-up B Body
Re: Shifter I'd [Re: John_Kunkel] #2735062
01/20/20 08:42 PM
01/20/20 08:42 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Great list John! up
