Old Barry Grant parts #2734575
01/19/20 05:57 PM
01/19/20 05:57 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
I have some parts, not carbs, that are pretty new looking but I have no paperwork and the parts have no
P/N's stamped on them.
I have a bypass regulator, 2 HR 220 fuel pumps, 2 canister filters that seem to go with fuel pumps as inlet
filters, 1 really big canister filter.
I'd like to know the micron ratings of the filters and whether replacement filter elements can be had.
Also I'd sure like to know the pressure rating range on the regulator, without having to rig up a circuit
and test it.
I can take pictures if that would help.
Anyone have any old BG literature ?
Re: Old Barry Grant parts [Re: hemienvy] #2734698
01/19/20 11:49 PM
01/19/20 11:49 PM
If those BG filters(BG#400 and BG#500 ) have paper elements in them they are rated at 10 micron, not to be used between the pumps and fuel tanks tsk
I did that and found out the hard way those filters only belong between the pump and carb or between the regulator and carb. up
EDIT: BTW, I was told by one of the BG employees that their 400 and 500 fuel filter element was the same as the early ford had in their mechanical pumps back in the 1960 scope
Re: Old Barry Grant parts [Re: Cab_Burge] #2734707
01/20/20 12:33 AM
01/20/20 12:33 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
This guy carries some repair parts. There is a guy on Racing Junk too.
https://www.ebay.com/itm/BG-BARRY-G...arts&hash=item3374600dbb&vxp=mtr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Old Barry Grant parts [Re: hemienvy] #2734890
01/20/20 01:39 PM
01/20/20 01:39 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Allstate Carb has some BG items. Their standard filter is rated at 10 micron the alcohol compatible stainless steel is rated @ 75 micron. I am running the BG 5000 filter before my Mallory 250 pump and have not seen and problems. The 220 HR pump came with a regulator . I am using that regulator . I started with the 220 HR and had some problems with it locking up, and switched to the Mallory.
https://allcarbs.com/product/bg-5000-fuel-filter-element/
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
