Page 3 of 5 1 2 3 4 5
Re: Race Engine reality, what works [Re: moparx] #2734432
01/19/20 12:21 PM
01/19/20 12:21 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Originally Posted by moparx
hoping i cam get my charger out this year, first time since 2007.
hoping i can crack the mid 11's with .030 over 440, 11.5:1 RPM heads, 3.91/29" tire. [or close biggrin]
beer
1/8 mile ? .... whistling wave shruggy Santa4
beer
Re: Race Engine reality, what works [Re: DaveRS23] #2734446
01/19/20 12:35 PM
01/19/20 12:35 PM
Sterling Heights, MI
John_T_Brown Offline
Words of wisdom from a Super Stock racer... Make your best LOW friction short block assembly, choose your best roller cam for your cylinder head flow rate, then hang an induction system that is not a torque limiting device (headers included). After all is done with the engine choose a converter that will flash between 6400 and 6800 rpm (done the data acquisition). REMEMBER this is Super Stock racing! The rest is low rotating mass components for the drivetrain. AND one final thing is the best shock program (shocks) money can buy for your budget that is monitored with data acquisition.
DATA IS YOUR FRIEND grin
3500# car, 400c.i. engine, 1.21 60' , 9.20's
If it ain't broke fix it anyway!
Re: Race Engine reality, what works [Re: John_T_Brown] #2734468
01/19/20 01:09 PM
01/19/20 01:09 PM
MI
68shifter Offline
68shifter  Offline
MI
Plug wires-I’ve has MSD, Ultra40’s and Firecore over the years. Each supposedly better than the last and never have I seen one bit of difference. I’ve always disliked the MSD’s and how they don’t “click” on as good. But never changed any et.
Good clutch-screw the torque converter.
10deg locks vs 7deg locks. Last time I had the heads freshened he was all about I think going from 10 to 7. Spent a bunch on ti retainers and locks. The time before that I could have swore he wanted it the other way. I don’t remember. But I have never seen a change in lash, et or anything else from one to the other. Heck if I know.
My M/T 3074s were worth .03 in 60’ over Phoenix. A little lighter and seem to last a little better.
I bought a used 1250 Doninator years ago from a local guy. Threw a kit in it and away I went. Sent it to Pro-Systems couple years later. $600 bucks or whatever it was. No difference. Maybe idled a little cleaner. I still wonder how much it all matters in a stick car that’s never below 5k but I’m not smart either.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Race Engine reality, what works [Re: 68shifter] #2734573
01/19/20 05:48 PM
01/19/20 05:48 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Well in my opinion its all about a combination so there are many roads to success.
In my experience good results have come from high compression, lightweight engine components, vacuum pumps and certainly not least quality torque converters and transmissions.
I also feel that strong pushrods, quality rocker arms and with a roller cam stout spring pressures are important.
While it can be expensive I think Andy F has shown that money spent with folks like Wilson can be rewarded.
Of course all of this would be tempered by what do you want to do? Just go fast, run brackets, indexes, small tire, NHRA classes etc.
Good luck with it!
Re: Race Engine reality, what works [Re: 340Cuda] #2734583
01/19/20 06:10 PM
01/19/20 06:10 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
For me it was going from B1 original's to the PSO head along with a 55MM .900 lift cam...While I gained around 100hp thru out the RPM range it ran right by my 20yr old chassis capabilities...We have to take so much power out to be able to get down the track that we're still stuck in the high 4.70 to low .80's and need to be in the mid 60's...So now it looks like chassis prison and another lost season !!
Re: Race Engine reality, what works [Re: Gary Robbins] #2734594
01/19/20 06:32 PM
01/19/20 06:32 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I have not seen anyone or I missed it, talk about Carbon Fiber Drive shafts and or Polished finish on the rear gears, what if any did they pick up.
Re: Race Engine reality, what works [Re: 10secGTX] #2734604
01/19/20 06:59 PM
01/19/20 06:59 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
There was a post on Classracer about lightweight ring gears and the finishes came up.
http://classracer.com/classforum/showthread.php?t=75119
Floyd Lippencott IV
Re: Race Engine reality, what works [Re: BradH] #2734658
01/19/20 09:55 PM
01/19/20 09:55 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by BradH
The OP mentioned straightening the lifter bores... Assuming he means bushing them along with blueprinting their locations, I understand the oil control benefits. But is there a measurable performance improvement?"
EDIT: This is of interest to me because my current block has had the lifter bores corrected bushed, but it's "tired" and the cylinders couldn't take anything more than a re-hone during the last rebuild. I've got a freshly machined block to replace it, but the one job the shop that did the work wasn't equipped to do was the lifter bores. Not sure if I should plan to haul it somewhere else to get that done, or build it as is.
Well, it's supposed to be worth 20 hp if you believe THIS DYNO TEST
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Race Engine reality, what works [Re: pittsburghracer] #2734770
01/20/20 08:47 AM
01/20/20 08:47 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by pittsburghracer
Lots of guys like me to spend big money for little gain. Again 95% of us are bracket racers or street n strip guys so thin ring packs, lightweight components, belt drives, and vacuum pumps show little gains. A 5.00 lock ring on your distributor works wonders and is surely cheaper than other options out there. As far as deck plates I personally don’t use them. How long does a dead prefectly machined block in the machine shop stay perfect when the crank is bolted in place with 8 rods and spinning 7200 rpm. Now throw in the “heat factor). What does the block do when at Racing temps. Do you think it stays perfect like in the machine shop. Your guess is as good as mine but I’m thinking no. I like spending around 1000.00 to machine a block and balance an assembly at a shop I trust rather than crazy money making the shop owner rich. If it makes you sleep better at night then go ahead and spend big money. If you are sitting at home because you can’t afford the tricks, maybe it’s time to stop believing the ragazines written by guys that get paid to suggest you spend your hard earned money.
My Indy Maxx block has never had as much pan vac as it has after BES honed it. And he told me to run it as cold as possible 100* if I can at the starting line
....BAD A$$ STREET CAR.....
Re: Race Engine reality, what works [Re: Gary Robbins] #2734771
01/20/20 08:48 AM
01/20/20 08:48 AM
N
n20mstr Offline
n20mstr  Offline
N
let me borrow the engine....LOL
why cant your ladder bars handle the power??
Re: Race Engine reality, what works [Re: Hemi_Joel] #2734800
01/20/20 10:08 AM
01/20/20 10:08 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Barton has claimed HP increases from it, too. My first thought after reading the article was... how far off was the lifter bore alignment to have made that much difference? Regardless, thanks for the link.
Re: Race Engine reality, what works [Re: BradH] #2734865
01/20/20 12:34 PM
01/20/20 12:34 PM
Barton has claimed HP increases from it, too. My first thought after reading the article was... how far off was the lifter bore alignment to have made that much difference? Regardless, thanks for the link. [/quote] iagree work
Re: Race Engine reality, what works [Re: pittsburghracer] #2734877
01/20/20 01:03 PM
01/20/20 01:03 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
The lack of a deck plate use surprises me. I thought that was standard in any HP build. The difference is plate honing cost is minimal in my area, so why not make every effort to maintain block integrity?
Re: Race Engine reality, what works [Re: cudadoug] #2734879
01/20/20 01:08 PM
01/20/20 01:08 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Boost. Never fails.
Re: Race Engine reality, what works [Re: Dragula] #2734882
01/20/20 01:11 PM
01/20/20 01:11 PM
cudadoug Offline
cudadoug  Offline
Originally Posted by Dragula
Originally Posted by TRENDZ
This most likely falls outside of the original topic, but there is no single more important part to having a fast car, than the torque converter.
It is definitely not outside the topic.....Many combos are held back by the wrong or bad torque converter. This is especially critical to the folks that run a glide....Typically you know when you have the right converter, but not so the other way around.
YEP! Seen many combos that don't run as good as they should due to the converter. And vice-versa.
Re: Race Engine reality, what works [Re: cudadoug] #2734883
01/20/20 01:12 PM
01/20/20 01:12 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I Feel my junk runs pretty good without it. I guess the R3 block in my Duster now has been bored with deck plates but not by me, and when I rebuild it over the winter I will be hand honing it myself. My machine shop that I use probably doesn’t even have a small block Mopar deck plate. I never bothered to ask.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Race Engine reality, what works [Re: Brian Hafliger] #2734944
01/20/20 03:30 PM
01/20/20 03:30 PM
cudadoug Offline
cudadoug  Offline
Originally Posted by ou812
I sealed my 6PK scoop to my carb... worth a tenth and 1.5mph. Removed it and jetted down, lost everywhere...jetted back up and gained some, sealed and gained all back. Jetted up from there with it sealed and lost.
Working on the car, specifically the front and rear suspension, and launch were the biggest gains.
Working ON THE CAR can be huge!
Once upon a time...
Roller cammed 440 in a back half E body. 10.80's @ 124. Fresh trans and tuned up converter, new HAL (now QA1) adjustable shocks on all four corners, opening valve lash .010: 10.40's @ 127 were the result. Added a rear tire that was 1.5" bigger in roll out: 10.30's @ 128, best of 10.36 @ 129.
10.80's to 10.30's and other than the valve lash, never touched the motor, or the tune up.
Re: Race Engine reality, what works [Re: pittsburghracer] #2735200
01/21/20 09:54 AM
01/21/20 09:54 AM
BradH Offline
BradH  Offline
... As far as deck plates I personally don’t use them. How long does a dead prefectly machined block in the machine shop stay perfect when the crank is bolted in place with 8 rods and spinning 7200 rpm. Now throw in the “heat factor). What does the block do when at Racing temps. Do you think it stays perfect like in the machine shop. Your guess is as good as mine but I’m thinking no.
When I took my 4.380" RB block in to get a touch-up hone before the last reassembly, the machinist who does my block work now told me he tried to do it w/ a torque plate first, but it distorted the cylinders too much. That surprised me because when the block was bored to 4.380" by another shop (who, even if still in business, I won't deal with) I specifically paid to have the block deck-honed... and the receipt states clearly that I paid the additional charge for it.
I told this to the machinist and his response was: "Well, he may have put a torque plate on it... but he sure as He11 didn't tighten it down." This guy prepped my other block, which is a 4.375" finished-honed w/ a torque plate. And I've been wondering even before this thread started whether the 4.375" block done "right" will actually make any more power than the "tired" 4.380" block w/ out-of-round bores and excessive piston-to-wall clearances. I'm not sure I'd bet on even a 10 HP improvement, but a scientific A-B comparison test ain't gonna happen, much as I'd like to know.
Re: Race Engine reality, what works [Re: BradH] #2735219
01/21/20 11:00 AM
01/21/20 11:00 AM
an8sec70cuda Offline
Just a few things I can think of right now that I've seen from running my own stuff...
1. A vacuum pump only helps w/ oil leaks on a mid 9 sec NA 572. Saw zero performance difference, but it did stop the little annoying oil leaks. Had low tension rings in it too. Might work better on other combos, but I certainly don't think it's worth it.
2. I ran my 572 hemi for 13 years and freshened it up a couple times in that time frame. Obviously it got more and more worn at every freshen up...speaking about the pistons and bores. A simple dingle berry hone and re-ring and it ran just as fast as it did when it was fresh. Even though the wall clearance had grown .003" and had .002" taper and out of round.
3. Zero difference b/t spark plug wires. MSD, Taylor, and Firecore...pick the ones that LOOK good to you, b/c they will run the same. I think the ignition market has more gimmick sales pitches than any other...well, maybe motor oil has more.
4. A couple of my engines that ran very well for what they were, weren't honed w/ torque plates. My hemi was done w/ one and I recently bought my own plate b/c no one around here had one. Not saying they aren't a good idea, but I have no idea what it's worth power-wise and a lot of folks seem to think it's worth 200 hp, lol. I know on my hemi, the bore is out of round .001" without the plate bolted down. See my 2nd example above for thoughts on that.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Race Engine reality, what works [Re: BradH] #2735220
01/21/20 11:05 AM
01/21/20 11:05 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's really cool to see this kind of transparency re: hand honing and even ball honing, as it matches up to a few discussions
I've had with folks I consider smarter than me.
Rich H.
Esse Quam Videri
