Page 2 of 3 1 2 3
Re: A body front steer rack [Re: 6bblFLASH] #2733720
01/16/20 07:37 PM
01/16/20 07:37 PM
PA
moparacer Offline
moparacer  Offline
PA
Quote
Lower ball joints are swapped on bothe cars.
Doesn't this induce a bunch of positive camber when you do that? I was looking at trying that one time and I remember the ball joint was angled and offset so I automatically ruled that possibility out.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: A body front steer rack [Re: moparacer] #2733737
01/16/20 08:26 PM
01/16/20 08:26 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Didn`t effect the camber. That I could see.
Did`nt have any issues getting everything to line up.
The 68` needs more caster,has power rack and ratio is too quick/light. However it is a lot of work to add caster or remove it. Tie-rod length and height would need to be changed also.......too lazy to do all that again.
At ride height the rack and tie-rods need to be somewhat level.
Beyond that you will get severe toe-in at max travel up or down---toe-out in the middle or a combination of both.,which is why a common band-aid is restrict front end travel. On a fast drag car you don`t need much travel which makes it a lot simpler. Street cars or roundy stuff is much much harder to retro-fit. Main reason I made my own K frame.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: A body front steer rack [Re: 6bblFLASH] #2733899
01/17/20 01:18 PM
01/17/20 01:18 PM
gregsdart Online content
gregsdart  Online Content
The key is a combination of rack length that fita the length of the lower control arms for zero bumpsteer and also places the tie rod end correctly for ackerman for a street car. For a race car(mine) zero ackerman saved my keester three times and allowed me to correct quickly when i blew an oil system gasket at 150 mph , got sideways at 125 mph on a slick track, and again at 135 mph when i hit a dip in the track with the brakes on hard.. I don't recall seeing many successfully recovering from being out of shape as bad as i was. Credit the fact that the front wheels stayed dead parallel at all steering angles so the front end didn't push me into a spinout.
Re: A body front steer rack [Re: gregsdart] #2734214
01/18/20 02:29 PM
01/18/20 02:29 PM
East Brunswick New Jersey
N
NoFrills Offline OP
NoFrills  Offline OP
N
Well I talked myself out of building one. To many other projects going on. This should be done in a few months.
Re: A body front steer rack [Re: NoFrills] #2734217
01/18/20 03:00 PM
01/18/20 03:00 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
That looks nice..
Re: A body front steer rack [Re: NoFrills] #2734219
01/18/20 03:04 PM
01/18/20 03:04 PM
PA
moparacer Offline
moparacer  Offline
PA
Is that a few months wait time for him to build you the suspension? And what does a setup like that cost?
I am probably going to go that route too so I can keep the factory spindles and brakes but I need to be going back together pretty quick for the start of the season.
Re: A body front steer rack [Re: NoFrills] #2734229
01/18/20 03:30 PM
01/18/20 03:30 PM
montana
BANDIT Offline
BANDIT  Offline
montana
That is a nice looking set up. Does it use your stock spindle then? Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: A body front steer rack [Re: BANDIT] #2734294
01/18/20 07:48 PM
01/18/20 07:48 PM
N
NoFrills Offline OP
NoFrills  Offline OP
N
Yes it uses stock spindles. It is alot better of price then most. I like that it is all moly tube. Says will save 65 pounds over stock set up.
Re: A body front steer rack [Re: NoFrills] #2734303
01/18/20 08:37 PM
01/18/20 08:37 PM
What brand is it and can you provide us contact info please help grin
Are you going to way it and all your old parts also?
The reason I'm asking is I had a early A body tube K frame, it weighed 2 lbs. less than the stock K frame did before cleaning the stock one shock
21 lbs. for the tube one and 23 lbs. for the stock K member on a 1000 lb. certified warehouse scale shock work
I have several 1967 and later stock A and B body K members so it will be interesting to hear on your weight differences on the B body K members only.
I've ben using elephant ears and front motor plates for years on my hot street and strip cars and I know all the engine mount parts add up on weight, my last BB Duster had right at 49.7 % weight on the rear tires, 50.3 % on the front tires boogie That baby would hook up in a mud puddle in the middle of a rain storm devilwhistling grin
AKA, aside it flat worked well upboogie
I did move the rear axle forward one inch ( I had to stretch the rear wheel wells five inches, three inches on the front side and two inches on the rear side wrench) and I moved the 400 block back as far back as I could and still get the valve covers off with the heater installed up
Re: A body front steer rack [Re: Cab_Burge] #2734338
01/18/20 10:45 PM
01/18/20 10:45 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Even adding a lot of gussits to my son's 68 Dart front X member and I added a lot, it was still about 28 pounds on my bathroom scale....
Now total weight, what is taken off and added back on?
The manual box VS Mustang II rack?
Stock slot motormounts VS motor plates with Elephant ears?
I can't see the items weighting much different.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: A body front steer rack [Re: NoFrills] #2734386
01/19/20 10:25 AM
01/19/20 10:25 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have this set up on my car as well. Been thru dragweek and won my class. With the cost of this set up don’t know why you would do it yourself. For what you see in pictures it is $1550. Tory Shellehamer makes them and you can find him on Facebook .
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: A body front steer rack [Re: Cab_Burge] #2734390
01/19/20 10:34 AM
01/19/20 10:34 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have weight the parts multiple times and posted them here and Facebook, it’s 65lbs difference.
With that much weight on rear tires were you trying for a wheel stander? 😎
Re: A body front steer rack [Re: 1967dartgt] #2734392
01/19/20 10:37 AM
01/19/20 10:37 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The big weight loss are the torsion bars, steering box, and linkage. Everything else can get real close with stock stuff. The stock control arms and modified K frame aren't enough different in weight to matter much.
Doug
Re: A body front steer rack [Re: dvw] #2734412
01/19/20 11:42 AM
01/19/20 11:42 AM
N
NoFrills Offline OP
NoFrills  Offline OP
N
I am changing all kinds of stuff on my car this winter. I do in joy problem solving and making my own stuff . For the amount of time i will spend planing and building it my self i cant justify building it. Ive seen this set up in action and it seems to work great. Tory also makes motor plates and header flanges. Chances are ill be hitting him up for some p7 ones.
Re: A body front steer rack [Re: NoFrills] #2734437
01/19/20 12:26 PM
01/19/20 12:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Really like the design of the lower control arm connections (triangle), rack is way to far forward but it can be moved. There’s a lot of spindles out there designed with the tie rod in front, just use the the proper ball joints. You don’t have to stay with the Chrysler type either. Speedway makes one for circle track. Just my 2 Cents
Re: A body front steer rack [Re: cudaman1969] #2734445
01/19/20 12:34 PM
01/19/20 12:34 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Rack is just in front of balancer. Where are you going to move it? Can’t go back farther the engine is there. I guess your gonna mount it under the engine and jack up ride height? Don’t see how your idea is possible.
Re: A body front steer rack [Re: 1967dartgt] #2734491
01/19/20 01:58 PM
01/19/20 01:58 PM
PA
moparacer Offline
moparacer  Offline
PA
Shot him a PM on Facebook. Thanks!
Re: A body front steer rack [Re: 1967dartgt] #2734835
01/20/20 11:32 AM
01/20/20 11:32 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If so I would not have it, I want the rack swivel centerline on the inner pivot of the lca and the tie rod tube parallel to the lca because as we know the upper and lower control arms pivot on a different arc. The higher the outside tie rod is the more it will toe outl on a wheely. This puts the rack below the balanced. I’ll add..IMO
Re: A body front steer rack [Re: 1967dartgt] #2734851
01/20/20 12:05 PM
01/20/20 12:05 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Looks like a great swap from the stock setup.
other than tubular uppers and strut bars to carry the weight of the coil holding the front up, what shock is needed? obviously a coil over type and I guess you can use your own length too
65lbs sounds great too !
....BAD A$$ STREET CAR.....
Re: A body front steer rack [Re: n20mstr] #2735260
01/21/20 12:54 PM
01/21/20 12:54 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I run a Afco da shock with 5 in stroke. I run one designed to fit a factory mopar in stock location. I believe my shock is part number 3850m but can’t remember for sure. If you are really serious I can go n my garage and get it for you.
Page 2 of 3 1 2 3
