'it took out the lifters' or 'cam'
#2734028
01/17/20 10:47 PM
01/17/20 10:47 PM
Posts: 2,252 IL
furious70
IL
A couple used engines near me, 09 ram shortblock with a 'bad cam' 11 car longblock with 'bad lifters'
Supposedly no junk in the oil, what could be wrong yet not catastrophic in these engines or no such thing they're just cores to be rebuilt?
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: 'it took out the lifters' or 'cam'
[Re: furious70]
#2734073
01/18/20 06:11 AM
01/18/20 06:11 AM
Posts: 80 Australia
aus370
Australia
Supposedly no junk in the oil, what could be wrong yet not catastrophic in these engines or no such thing they're just cores to be rebuilt? If you can't dismantle to inspect, best to assume it's a rebuilder. The one i got with one lobe gone, you could almost clean and re-assemble, if you were on a super budget. I found a heap of metallic paste on the magnetic part of the MDS solenoids : so you want to make sure to remove and inspect them.
[Re: aus370]
#2734090
01/18/20 09:56 AM
01/18/20 09:56 AM
Posts: 2,252 IL
furious70
IL
yes MDS and VVT. What's a good core price on a short and then longblock? between the 2 I think there's only 1 set of rockers, valve covers, manifolds, etc.
[Re: furious70]
#2734247
01/18/20 04:27 PM
01/18/20 04:27 PM
Posts: 12,408 Kalispell Mt.
HotRodDave
Kalispell Mt.
the lifter quits rolling and destroys the cam on 09+ 5.7. I have seen them where they go bad and everything else looks new inside, bearings, bores everything.
[Re: HotRodDave]
#2734290
01/18/20 07:30 PM
01/18/20 07:30 PM
Posts: 2,252 IL
furious70
IL
Dave, do you do something different for lifters when u out in a 392 cam then?
[Re: furious70]
#2734896
01/20/20 01:51 PM
01/20/20 01:51 PM
HotRodDave
Kalispell Mt.
well the lowest miles I seen a lifter go bad was 120,000 (typical between 150,000 and 200,000 and as high as 270,000 on original lifters), I figure if it lasts another 120,000 minimum then I done all right. The dodge dealer told me all the part numbers are the same now for 6.4 6.1 and 5.7 without any other way to know what is best that personal experience is all I got to go on.
[Re: Neil]
#2735028
01/20/20 06:49 PM
01/20/20 06:49 PM
Posts: 2,252 IL
furious70
IL
well, if Dave's data holds, what aftermarket lifter has as many road miles tested?
[Re: Wailin D]
#2735280
01/21/20 02:04 PM
01/21/20 02:04 PM
HotRodDave
Kalispell Mt.
I have heard the hellcat uses different (better?) lifters butt do not have any personal experience.
[Re: L4staero]
#2735344
01/21/20 05:20 PM
01/21/20 05:20 PM
Posts: 2,252 IL
furious70
IL
additionally revised to -AD now?
https://www.eastcoastmoparts.com/oem-parts/mopar-hydraulic-roller-lifter-rear-yoke-5038787ad?c=bD0yJm49U2VhcmNoIFJlc3VsdHMmYT1kb2RnZSZvPWNoYXJnZXImeT0yMDE4JnQ9ci10JmU9NS03bC12OC1nYXM%3D
[Re: Wailin D]
#2735811
01/23/20 12:02 PM
01/23/20 12:02 PM
Posts: 421 montana
BANDIT
montana
I just talked to Isky about the solid rollers in my race car, bearing ones are $900.00, bushed ones are $1250.00. Claim is 30-50% more life expectancy in bushed ones in my application. You have to decide from there. Those were Red Zones, also. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
