'it took out the lifters' or 'cam' #2734028
01/17/20 09:47 PM
01/17/20 09:47 PM
IL
furious70 Offline OP
IL
A couple used engines near me, 09 ram shortblock with a 'bad cam'
11 car longblock with 'bad lifters'
Supposedly no junk in the oil, what could be wrong yet not catastrophic in these engines or no such thing they're just cores to be rebuilt?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 'it took out the lifters' or 'cam' [Re: furious70] #2734043
01/17/20 10:30 PM
01/17/20 10:30 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Got to be some metal in there from the failures. Maybe good cores for a rebuild, though..... work
Re: 'it took out the lifters' or 'cam' [Re: furious70] #2734052
01/18/20 12:39 AM
01/18/20 12:39 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
MDS?
Re: 'it took out the lifters' or 'cam' [Re: furious70] #2734073
01/18/20 05:11 AM
01/18/20 05:11 AM
Australia
aus370 Offline
aus370  Offline
Australia
If you can't dismantle to inspect, best to assume it's a rebuilder. The one i got with one lobe gone, you could almost clean and re-assemble, if you were on a super budget.
I found a heap of metallic paste on the magnetic part of the MDS solenoids : so you want to make sure to remove and inspect them.
Stock 6.1 Hemi . 11.657 @ 113.54 , 3588 lbs.
Re: 'it took out the lifters' or 'cam' [Re: aus370] #2734090
01/18/20 08:56 AM
01/18/20 08:56 AM
IL
IL
yes MDS and VVT. What's a good core price on a short and then longblock? between the 2 I think there's only 1 set of rockers, valve covers, manifolds, etc.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 'it took out the lifters' or 'cam' [Re: furious70] #2734247
01/18/20 03:27 PM
01/18/20 03:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the lifter quits rolling and destroys the cam on 09+ 5.7. I have seen them where they go bad and everything else looks new inside, bearings, bores everything.
Re: 'it took out the lifters' or 'cam' [Re: HotRodDave] #2734290
01/18/20 06:30 PM
01/18/20 06:30 PM
IL
IL
Dave, do you do something different for lifters when u out in a 392 cam then?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 'it took out the lifters' or 'cam' [Re: furious70] #2734896
01/20/20 12:51 PM
01/20/20 12:51 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
well the lowest miles I seen a lifter go bad was 120,000 (typical between 150,000 and 200,000 and as high as 270,000 on original lifters), I figure if it lasts another 120,000 minimum then I done all right. The dodge dealer told me all the part numbers are the same now for 6.4 6.1 and 5.7 without any other way to know what is best that personal experience is all I got to go on.
Re: 'it took out the lifters' or 'cam' [Re: HotRodDave] #2735008
01/20/20 04:47 PM
01/20/20 04:47 PM
Eagle, Idaho
Neil Offline
Neil  Offline
Eagle, Idaho
So is it too thick of oil, or sludge buildup from not changing the oil, or something else that causes this?
If I were doing a rebuild I think I would want a set of aftermarket lifters instead of the oem ones???
Re: 'it took out the lifters' or 'cam' [Re: Neil] #2735028
01/20/20 05:49 PM
01/20/20 05:49 PM
IL
IL
well, if Dave's data holds, what aftermarket lifter has as many road miles tested?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 'it took out the lifters' or 'cam' [Re: furious70] #2735150
01/21/20 01:33 AM
01/21/20 01:33 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Just an FYI. Isky makes hydraulic roller lifters for G3 hemis with either the typical needle bearings or with a bushing instead of a needle bearing. I know using bushings isn't anything new, but it is fairly new for the G3 hemi. They say the bushing is offered for more extreme applications, but it would seem to be a possible solution to the failures if they aren't too cost prohibitive and are durable long term.
https://www.iskycams.com/downloads/GenIIIFlyer.pdf
Re: 'it took out the lifters' or 'cam' [Re: Wailin D] #2735280
01/21/20 01:04 PM
01/21/20 01:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have heard the hellcat uses different (better?) lifters butt do not have any personal experience.
Re: 'it took out the lifters' or 'cam' [Re: HotRodDave] #2735317
01/21/20 02:55 PM
01/21/20 02:55 PM
Eagle, Idaho
Neil Offline
Neil  Offline
Eagle, Idaho
The hellcats and demons won't get enough miles on them to fail. It appears that most of those cars are collector pieces and not daily drivers.
Re: 'it took out the lifters' or 'cam' [Re: Neil] #2735330
01/21/20 03:36 PM
01/21/20 03:36 PM
Australia
L4staero Offline
L4staero  Offline
Australia
I've done about 50 of these lifter failure engines.
Depending how long they are run determines how ruined they are.
Ive seen them fail as low as about 30k miles
At minimum the oil pump has eaten metal and the filter has caught it all. After that is varying levels of damage.
There has been something like 9 revisions on the lifters since 2012. Most notable are the lifters from 2016 up often referred to as "Hellcat" lifters with individual p/n being 787AC. Both mds and non mds lifters from 2016 up have the upgraded roller, axle, needle bearings which was the failure point
Re: 'it took out the lifters' or 'cam' [Re: L4staero] #2735344
01/21/20 04:20 PM
01/21/20 04:20 PM
IL
IL
additionally revised to -AD now?
https://www.eastcoastmoparts.com/oem-parts/mopar-hydraulic-roller-lifter-rear-yoke-5038787ad?c=bD0yJm49U2VhcmNoIFJlc3VsdHMmYT1kb2RnZSZvPWNoYXJnZXImeT0yMDE4JnQ9ci10JmU9NS03bC12OC1nYXM%3D
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 'it took out the lifters' or 'cam' [Re: furious70] #2735403
01/21/20 07:22 PM
01/21/20 07:22 PM
Australia
L4staero Offline
L4staero  Offline
Australia
Yes that's correct. That's revision from AC to AD came though around Aug last year. Previously the AC revision lasted about 3 yrs
Re: 'it took out the lifters' or 'cam' [Re: Wailin D] #2735811
01/23/20 11:02 AM
01/23/20 11:02 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I just talked to Isky about the solid rollers in my race car, bearing ones are $900.00, bushed ones are $1250.00. Claim is 30-50% more life expectancy in bushed ones in my application. You have to decide from there. Those were Red Zones, also. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.50@162. 4900 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
superhost passed wuab 43 cleveland ohio
by theraif. 02/22/20 12:07 AM
Head gasket on aluminum block
by hemienvy. 02/22/20 12:07 AM
Ram Tough? Hard hit and still runs......
by Satilite73. 02/21/20 11:56 PM
636 CI KB Hemi Block
by hemicar1971. 02/21/20 11:23 PM
Moparts Recent Posts
CARB SOAK
by skrews. 02/22/20 01:47 AM
Mega Block Questions
by Cab_Burge. 02/22/20 01:00 AM
by Cab_Burge. 02/22/20 12:55 AM
Mopar Trick Flow 240 Heads
by Cab_Burge. 02/22/20 12:48 AM
