engine compartment paint coverage #2733904
01/17/20 12:28 PM
01/17/20 12:28 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
My 69 Hemi Charger 500 will soon be in the painting process of its paint/body operation. I was curious.. I'm trying to get it as OEM correct as possible. I know the battery tray was installed prior to paint, so I'm curious on the coverage of body color. I'm sure the immediate underside of the tray didn't get much paint, but curious on the inner fender just under the battery tray and the support brackets.. Pictures would be great..
Thanks..
Troy
Houston Mopar Connection Club
Re: engine compartment paint coverage [Re: hemi68charger] #2733944
01/17/20 03:00 PM
01/17/20 03:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No two cars will be exactly the same.
Did you take photos as it came apart?
Re: engine compartment paint coverage [Re: Alaskan_TA] #2733979
01/17/20 06:12 PM
01/17/20 06:12 PM
Houston, Tx
Houston, Tx
Yes and it wouldn't have matter since someone painted the whole car orange back in '81-'82 make a General Lee. I agree, no two cars were the same but there was a general pattern in which cars were painted in terms of production...
Troy
Re: engine compartment paint coverage [Re: hemi68charger] #2733984
01/17/20 06:22 PM
01/17/20 06:22 PM
So Near, Yet So Far
topside Offline
topside  Offline
So Near, Yet So Far
What I can tell you from my original-paint cars is that the compartment & hood underside were pretty much covered, but not as well done as the exterior.
In some areas (backside of shock towers, for example) the paint was pretty thin, as were the frame rails below the top horizontal flange.
Backside of underhood contours was pretty thin.
The paint at the firewall had runs in a couple of mine.
Top of battery tray (under battery) tended to be fairly thick (bridging fasteners/tray).
Basically, a guy leaning into the compartment, waving the spray-gun kinda hurried, and a lot less care than we take restoring them...
Re: engine compartment paint coverage [Re: topside] #2734026
01/17/20 09:24 PM
01/17/20 09:24 PM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
i coat everything in engine compartment with 2 heavy coats. same with trunk.
superhost passed wuab 43 cleveland ohio
by theraif. 02/22/20 12:07 AM
Head gasket on aluminum block
by hemienvy. 02/22/20 12:07 AM
Ram Tough? Hard hit and still runs......
by Satilite73. 02/21/20 11:56 PM
636 CI KB Hemi Block
by hemicar1971. 02/21/20 11:23 PM
Moparts Recent Posts
CARB SOAK
by skrews. 02/22/20 01:47 AM
Mega Block Questions
by Cab_Burge. 02/22/20 01:00 AM
by Cab_Burge. 02/22/20 12:55 AM
Mopar Trick Flow 240 Heads
by Cab_Burge. 02/22/20 12:48 AM
