AAR - T/A Rear License Plate Bracket #2733855
01/17/20 10:37 AM
01/17/20 10:37 AM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Reading through the Dave Wise reference manual, Restoration and Judging Guidelines, he mentions that the ebody rear license plate bracket (P/N 3445763) was a one-year only part used only in 1970. According to the manual, the 1970 bracket had both the left and right sides of the bracket turned "up" along the sides of the license plate. Guessing this lead to finger cuts, etc., the bracket was redesigned for the 1971 - 1974 years where the sides of the bracket were turned "down" toward the tail panel.
I have performed the 2nd restoration on my AAR 'Cuda. My license plate bracket appears to be original to the car but has the redesigned (1971) license plate bracket. I know due to the late production of the AAR's T/A's, many parts that some of these cars received were for the 1971 production year (washer bottles, wheel trim rings, etc.).
My question is, can someone who has a "original" AAR or T/A please look at their rear license plate bracket and tell me if you have the 1970 bracket or the redesigned 1971 bracket.
Re: AAR - T/A Rear License Plate Bracket [Re: Imrare] #2733861
01/17/20 10:51 AM
01/17/20 10:51 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 Challengers did not have a rear license plate bracket, the plate screws went into inserts in the valance.
Re: AAR - T/A Rear License Plate Bracket [Re: Alaskan_TA] #2733874
01/17/20 11:32 AM
01/17/20 11:32 AM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
That's right, I should have thought of that, they had the filler neck on the quarter panel. Guess then I'm only asking about AAR 'Cudas or any 'Cuda built after mid-April as my car was built on April 13th. Thank you.
Re: AAR - T/A Rear License Plate Bracket [Re: Imrare] #2733881
01/17/20 11:42 AM
01/17/20 11:42 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I have two AARs. I can check later if I go to the shop and get some pictures. I’m sure both are original to the cars . I have one built 3/31 and one built 4/09.
Re: AAR - T/A Rear License Plate Bracket [Re: fastmark] #2733890
01/17/20 11:57 AM
01/17/20 11:57 AM
Metro St. Louis
FM3AAR Offline
FM3AAR  Offline
Metro St. Louis
FWIW, mine's late March production and the ends are turned down.
Re: AAR - T/A Rear License Plate Bracket [Re: Imrare] #2733901
01/17/20 12:21 PM
01/17/20 12:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Well, Barracudas also. The brackets were not Cuda specific.
And.....
The fender tag date may or may not be the actual build date since those were not actually recorded back then.
My T/A had a tag date of 417 but the original engine was assembled 4 22, so the car was built days after the tag date.
Re: AAR - T/A Rear License Plate Bracket [Re: fastmark] #2733943
01/17/20 02:57 PM
01/17/20 02:57 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Thank you Fastmark, I would appreciate it if you could look and let me know.
FM3AAR - I suspect all AAR's have the turned down (1971) bracket. Thank you for the information.
Re: AAR - T/A Rear License Plate Bracket [Re: Imrare] #2734309
01/18/20 07:45 PM
01/18/20 07:45 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Well, I went to the shop and looked at my cars but did not refresh my memory and read your post. It’s the sides that are different, not the bottom. I’ll look again. Sorry.
Re: AAR - T/A Rear License Plate Bracket [Re: fastmark] #2734475
01/19/20 12:16 PM
01/19/20 12:16 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Right, the sides. If your AAR's have the redesigned 1971 bracket, which I believe they will, the sides of the bracket will turn down toward the tail panel. Thanks.
Re: AAR - T/A Rear License Plate Bracket [Re: Imrare] #2735145
01/21/20 12:23 AM
01/21/20 12:23 AM
NY
LTLBEE Offline
LTLBEE  Offline
NY
The bracket on my 4 07 build date AAR has the turned down edges
Re: AAR - T/A Rear License Plate Bracket [Re: LTLBEE] #2736488
01/25/20 12:16 PM
01/25/20 12:16 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I finally made it to the shop and I have three cars with the frame turned in at the sides. Two are AAR with build dates of 3/31 and 4/08 and a 3/31 Cuda built in LA.
Re: AAR - T/A Rear License Plate Bracket [Re: fastmark] #2737431
01/28/20 01:07 PM
01/28/20 01:07 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
If the WISE manual indeed does say "up". then it is wrong, All the rear brackets in 1970 for Barracuda were smooth and had no lip on the right and left side. That was changed to a lip that was "up" in 1971 and up. There were more cosmetic changes to that bracket in 1972(various holes in the face of it) but they are irrelevant to this discussion.
Cuda 340 shaker feet brackets
by AARCONV. 02/27/20 08:06 AM
1964 Polara Convertible with Max Wedge
by 65pacecar. 02/27/20 07:26 AM
66 Valiant - $700
by not_a_charger. 02/27/20 07:04 AM
1970 Dodge Coronet Superbee Engine 440
by tomsjack. 02/27/20 03:32 AM
Moparts Recent Posts
Got my Glen-Ray radiator back
by Rhinodart. 02/27/20 08:41 AM
AMD stops producing a lot of sheetmetal
by 5thAve. 02/27/20 08:41 AM
Garage Condos?
by jcc. 02/27/20 08:40 AM
'73 Duster 340 actually IS a survivor
by mopars4ever. 02/27/20 08:28 AM
