Re: Where to install an electric fuel pump?
[Re: 70sixpkrt]
#2729366
01/02/20 03:14 PM
01/02/20 03:14 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
You should always mount an electric pump BELOW the fuel tank normal fluid level. They do not like to suck as much as push.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Cab_Burge]
#2729541
01/03/20 12:43 AM
01/03/20 12:43 AM
Posts: 1,262 New York, USA
Chargerfan68
New York, USA
I tried mounting a pump up above the axle in front of the tank but no matter what i did, could not get that pump to prime and pull fuel. I moved the pump to the inside of the pass frame rail next to the tank and a bit lower, and instant prime. But, i have a friend that mounted it up there and has no problems. Mine are 68 and 73 b-bodies.
[Re: Chargerfan68]
#2729588
01/03/20 09:52 AM
01/03/20 09:52 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
I tried mounting a pump up above the axle in front of the tank but no matter what i did, could not get that pump to prime and pull fuel. I moved the pump to the inside of the pass frame rail next to the tank and a bit lower, and instant prime. But, i have a friend that mounted it up there and has no problems. Mine are 68 and 73 b-bodies. I had issues getting a prime when I had a pump on the trunk frame rail. Do yourself a favor and get an in tank setup, it's worth it.
[Re: 70sixpkrt]
#2729606
01/03/20 10:40 AM
01/03/20 10:40 AM
Posts: 11,891 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I mount mine on the shock cross member just ahead of the sender/pick-up. Have done that on several cars over the decades and the one on the Cuda now has been there for 15 years or so. And since my cars are street cars I don't want to hear that pump. So I mount it on a piece of rubber. Usually a piece cut out of a tire. Lasts forever that way and really knocks down the noise.
Master, again and still
[Re: 70sixpkrt]
#2729768
01/03/20 07:38 PM
01/03/20 07:38 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'll try to get some pics tomorrow.
[Re: GoodysGotaCuda]
#2730377
01/05/20 07:52 PM
01/05/20 07:52 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have my Holley pump right in front of my stock gas tank by the sending unit above the rear diff. Its not lower then the tank as its actually even with it or near the top of the tank. Its not many places to mount it lower then the stock tank. It pulled fuel instantly and has never ben a problem running in the 10's with a 3/8 line. I will say whenever I install a new electric pump I always put a bit of engine oil in the pump so it does not start dry and helps it seal well when first pulling fuel into it. I have never had a problem with the Holly pump mounted like that. Ron
[Re: 70sixpkrt]
#2733334
01/15/20 12:49 PM
01/15/20 12:49 PM
Posts: 1,106 michigan
440whiteboy
michigan
I'm going to install a Carter P4594 electric fuel pump and want to know where you guys put it. I'm looking for any pictures of a 70 B Body with a Dana 60. I'm thinking about just above the fuel sending unit but want to see some pics. thanks. I made a metal shield to help keep stones away mounting outside of frame shown in this pic.
They only see Stars... when hit by a Mopar!
[Re: 70sixpkrt]
#2733492
01/15/20 10:19 PM
01/15/20 10:19 PM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
There are a few brands of electric pumps that will effectively lift fuel from above the tank. Most will not, and or will cavitate if mounted that way. Less is more when it comes to lifting fuel above tank level. I use a 2 speed Fuel Labs pump mounted at the top of my tank hooked to a pair of Holley Hydramats.. The high speed switch kicks on when the secondaries open using a micro switch. The pump runs at a cooler low speed on the primaries
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: DaveRS23]
#2733824
01/17/20 09:33 AM
01/17/20 09:33 AM
Posts: 767 NW PA
V10nacuda
NW PA
I mount mine on the shock cross member just ahead of the sender/pick-up. Have done that on several cars over the decades and the one on the Cuda now has been there for 15 years or so. And since my cars are street cars I don't want to hear that pump. So I mount it on a piece of rubber. Usually a piece cut out of a tire. Lasts forever that way and really knocks down the noise. What he said! Same deal used a holly Blue Pump and Fram filter and housing. Drag race and street drove that thing for close to 10 years it had no issues!
[Re: Dave_J]
#2735199
01/21/20 09:51 AM
01/21/20 09:51 AM
DaytonaTurbo
Manitoba, Canada
You should always mount an electric pump BELOW the fuel tank normal fluid level. They do not like to suck as much as push. Agreed. However I have purchased two vehicles that had electric fuel pumps mounted up high in the engine compartment and never had any issues with them.
[Re: DaytonaTurbo]
#2735208
01/21/20 10:17 AM
01/21/20 10:17 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I put one right in front of the passenger side spring hanger, easy access and worked good for ages.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
