Re: 432 Big Block F1X Procharger [Re: Jeremiah] #2733357
01/15/20 01:03 PM
01/15/20 01:03 PM
Sidney,Ohio
challenger1320 Offline OP
Sidney,Ohio
Not sure but I will try and find out
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2733369
01/15/20 01:51 PM
01/15/20 01:51 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Cool I am very interested in valve train specs too if it's not a big secret. Does the engine use a steel exhaust valve?
Re: 432 Big Block F1X Procharger [Re: Jeremiah] #2733445
01/15/20 06:11 PM
01/15/20 06:11 PM
Sidney,Ohio
Sidney,Ohio
I have the dyno sheets but do not how to attach them if someone will do it I can send them to them
Re: 432 Big Block F1X Procharger [Re: challenger1320] #2733478
01/15/20 08:31 PM
01/15/20 08:31 PM
birdtracker Offline
birdtracker  Offline
lets see if this works . Birdtracker
Re: 432 Big Block F1X Procharger [Re: birdtracker] #2733486
01/15/20 08:58 PM
01/15/20 08:58 PM
After looking at the HP gain per 100 RPM on that dyno sheet it looks like to me it was nowhere near peak HP RPM at 8000 RPM.
That leads me to believe that motor probably has another 60 to 100+ HP in it closer to 8500 RPM twocents work
Hopefully the team will find out where that motor wants to be shifted at on the RPM to make the car go as fast as it can luck work
Re: 432 Big Block F1X Procharger [Re: birdtracker] #2733489
01/15/20 09:06 PM
01/15/20 09:06 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I assume you are using a boost reference fuel pressure regulator. it starts off at 9.5 PSI difference and ends at 13.6 PSI. I thought it should maintain a steady pressure over the reference pressure.
Joe
Without Data, you’re just another guy with an opinion.
Re: 432 Big Block F1X Procharger [Re: sr4440] #2735127
01/20/20 11:29 PM
01/20/20 11:29 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
It’s going in Ron’s dragster. Anyone that knows Ron, knows he runs the balls off of everything he owns. The goal here would be big power with concentration on longevity and consistency versus a max power effort.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: 432 Big Block F1X Procharger [Re: Irun5snd8th] #2735349
01/21/20 04:43 PM
01/21/20 04:43 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
He might still have a good bit of power left in that combo just based on the timing. I've messed with a few procharged methanol set ups before and depending on how they're built, methanol seems to like the "abuse" - high compression, aggressive timing and plenty of fuel lol.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
