Barracuda Dash Emblem
#2733363
01/15/20 02:35 PM
01/15/20 02:35 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
What is a good adhesive to use to affix a replacement Barracuda emblem. I don't see the push pins holding w/o an adhesive.
Ok
Re: Barracuda Emblem
[Re: Alaskan_TA]
#2733405
01/15/20 05:03 PM
01/15/20 05:03 PM
cudatom
Massillon, Ohio
Sorry, yes it is for the dash. I thought I has said that but didn't. Sucks getting old.
Ok
[Re: burdar]
#2733625
01/16/20 02:14 PM
01/16/20 02:14 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
My 73 Challenger script had little plastic retainers on the back side but that had to be done before the vinyl was stretched over the dash frame. No way to do that with a replacement dash pad. Go to your local parts store and look for an emblem adhesive. You are correct as always burdar, the emblem was installed in the vinyl before it was installed on the pad. I would also use black 3M emblem adhesive.
