Small block guys #2733382
01/15/20 03:40 PM
01/15/20 03:40 PM
CA.
RAY1969CARS Offline OP
CA.
What are your thoughts on Milodon gear drives ??
Re: Small block guys [Re: RAY1969CARS] #2733384
01/15/20 03:45 PM
01/15/20 03:45 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My brother has two of them, both in Oldsmobile engines, and likes them a lot. One is a driver and it's been fine so far. You can hear them if someone tells you there are in there, but they are not really that noisy like twin gear floating setups that Chevy guys use.
Worse part is getting the lash set correctly.
Re: Small block guys [Re: Neil] #2733387
01/15/20 03:48 PM
01/15/20 03:48 PM
CA.
CA.
How hard are we talking?
Re: Small block guys [Re: RAY1969CARS] #2733391
01/15/20 03:59 PM
01/15/20 03:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I think you run some paper thru the gears to set up the gap and then drill the holes to attach the idler gear plate or something like that. They do come with instructions and worse case you just call them and they'll help you. Oldsmobile install may differ from the Mopar install too.
Re: Small block guys [Re: Neil] #2733396
01/15/20 04:21 PM
01/15/20 04:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
What are those used for?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block guys [Re: pittsburghracer] #2733402
01/15/20 04:40 PM
01/15/20 04:40 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
to make noise
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Small block guys [Re: RAY1969CARS] #2733424
01/15/20 06:17 PM
01/15/20 06:17 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Had one on my 440 sb for about 10 yrs, no issues. Strip of news paper sets the lash.
Re: Small block guys [Re: rickraw] #2733430
01/15/20 06:27 PM
01/15/20 06:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I run a Keith Black unit on my SB and its just a piece of paper to set it... love it and its quiet
wave
Re: Small block guys [Re: pittsburghracer] #2734623
01/19/20 07:53 PM
01/19/20 07:53 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
In place of the factory timing chain setup, doesn't wear out like nylon chains do.
Plymouth Makes It!
Re: Small block guys [Re: RAY1969CARS] #2734745
01/20/20 02:51 AM
01/20/20 02:51 AM
Washington
madscientist Offline
Washington
Worth every penny. I set the lash with a dial indicator. Never liked the paper deal.
If they make noise, something is wrong.
