Barracuda Dash Emblem #2733363
01/15/20 02:35 PM
01/15/20 02:35 PM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
What is a good adhesive to use to affix a replacement Barracuda emblem. I don't see the push pins holding w/o an adhesive.
Ok
Re: Barracuda Emblem [Re: cudatom] #2733379
01/15/20 03:23 PM
01/15/20 03:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There should be tube nuts that the push pins go into. https://www.ebay.com/itm/Barrel-Cli...etainer-Nuts-Ford-GM-Mopar/111929651912? You can get them at ACE hardware.
Re: Barracuda Emblem [Re: stumpy] #2733385
01/15/20 03:45 PM
01/15/20 03:45 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you're set on using something else, there are "emblem adhesives" that you should be able to find at your local parts store.
Re: Barracuda Emblem [Re: burdar] #2733388
01/15/20 03:51 PM
01/15/20 03:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Interior like the small one on the dash of a '70 or exterior?
Re: Barracuda Emblem [Re: Alaskan_TA] #2733405
01/15/20 05:03 PM
01/15/20 05:03 PM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
Sorry, yes it is for the dash. I thought I has said that but didn't. Sucks getting old.
Ok
Re: Barracuda Emblem [Re: cudatom] #2733561
01/16/20 10:12 AM
01/16/20 10:12 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 73 Challenger script had little plastic retainers on the back side but that had to be done before the vinyl was stretched over the dash frame. No way to do that with a replacement dash pad. Go to your local parts store and look for an emblem adhesive.
Re: Barracuda Emblem [Re: burdar] #2733625
01/16/20 02:14 PM
01/16/20 02:14 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
You are correct as always burdar, the emblem was installed in the vinyl before it was installed on the pad. I would also use black 3M emblem adhesive.
Re: Barracuda Emblem [Re: burdar] #2733759
01/16/20 09:37 PM
01/16/20 09:37 PM
Massillon, Ohio
cudatom Offline OP
cudatom  Offline OP
Massillon, Ohio
Thank you
Ok
