stock stroke 340 pistons.
#2733328
01/15/20 12:30 PM
01/15/20 12:30 PM
Posts: 58 Wi
Scat
Wi
Been looking all over and am trying to find 11 to 11.5 compression pistons. Everything I have seen are 9.5 to 1 or 13.5 to 1. The pistons are going with a 60cc combustion chamber. Trying not to special order anything. Thanks
73 Duster 340 a518 6pack
Re: stock stroke 340 pistons.
[Re: Scat]
#2733341
01/15/20 01:03 PM
01/15/20 01:03 PM
Posts: 9,308 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
What bore, hyper or forged? Closed chamber head?
STOP POTATO HATE!
[Re: Scat]
#2733358
01/15/20 02:03 PM
01/15/20 02:03 PM
Posts: 20,600 in a cattle trailer down by th...
Guitar Jones
Been looking all over and am trying to find 11 to 11.5 compression pistons. Everything I have seen are 9.5 to 1 or 13.5 to 1. The pistons are going with a 60cc combustion chamber. Trying not to special order anything. Thanks I had to order custom pistons for my 340's, couldn't find any off the shelf pistons that would work.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Scat]
#2733374
01/15/20 03:11 PM
01/15/20 03:11 PM
Posts: 4,457 Washington
madscientist
Washington
Been looking all over and am trying to find 11 to 11.5 compression pistons. Everything I have seen are 9.5 to 1 or 13.5 to 1. The pistons are going with a 60cc combustion chamber. Trying not to special order anything. Thanks Google TRW 2216 IIRC and you can use those. Are they the lightest piston out there? No, but they aren't as bad as most think. You should be able to find them in any oversize up to .060 if that's what you need. With those Pistons you can set your combustion chamber volume and then mill the dome down to get the CR you want. Also you'll need to stick the piston deck .045-.050 OUT OF THE BORE to use the least dome you can and get some quench. Use an .039 gasket and only mill the heads far enough to get .050 or so piston to head clearance (you can squeeze it to .040 but you gain nothing and you'll still have some room to mill the heads later if you need to). You should be able to get what you want with a dome of .150-.200 and get the CR you want.
[Re: madscientist]
#2733404
01/15/20 04:51 PM
01/15/20 04:51 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you’re planning on using a closed chamber head and zero deck ...... you’ll either need to get the heads down near 55cc’s, or use a piston with a net dome volume of around 0cc’s(with 60cc heads).
Open chamber heads will allow positive deck heights...... but then you’ll have to balance the chamber volume, gasket thickness, quench pad area depth, valve pocket volume, etc.
The easy button is a 4” crank.
[Re: justinp61]
#2733506
01/15/20 11:49 PM
01/15/20 11:49 PM
Posts: 3,504 DFW
mr_340
DFW
The tops of the Speed-Pro L2316F pistons are about .500" thick. You could easily cut off the .045" or so to get a zero deck. That would take some weight out of them as well. I seem to remember they are around the stock 340 piston weight (~750g).
Floyd Lippencott IV
[Re: mr_340]
#2733645
01/16/20 03:03 PM
01/16/20 03:03 PM
fast68plymouth
So. Burlington, Vt.
The first incarnation of my 340 used L2316’s.
With the fairly good sized Crane Hyd cam I had for it, I discovered the valve pockets weren’t generous....... and since I had the short block all assembled and didn’t want to take it all apart to flycut the pistons, I ended up having to install a smaller/wider cam in the motor.
My point is....... the stock replacement style pistons aren’t as accommodating for bigger cams as what newer design HP pistons would be.
If you’re not planning on putting too much cam in it....... it probably won’t be an issue.
The TRW’s are heavy...... about 890g piston and pin. A set of SRP’s would be over 200g lighter .... each(almost 4lbs lighter for the 8).
[Re: fast68plymouth]
#2734434
01/19/20 12:22 PM
01/19/20 12:22 PM
Posts: 58 Wi
Scat
Wi
The TRW’s are heavy...... about 890g piston and pin. A set of SRP’s would be over 200g lighter .... each(almost 4lbs lighter for the 8). I wanted to keep machining to a minimum with trying to go with some pistons and milling them down. More I see it a 416 or a 372 might be a cheaper option then trying to achieve what I want to do. I am looking at a fairly roudy solid roller camI (NT/EXH - Dur @ .050” Lift: 258°/262° RR: 1.5/1.5 Gross Lift: .624”/.627” LSA: 108° RPM: 3000 to 7000 Redline: 7500) Would also like to keep the rotating mass down too and make it live.
