Trick Flow Head Stud kit question? #2733059
01/14/20 06:04 PM
01/14/20 06:04 PM
moparAL Offline OP
moparAL  Offline OP
I recently bought a pair of TF Heads for my big block, I want to attach them with studs. What manufacture would you recommend. If any members have bought TF heads and attached them with studs, What did you end up buying? Thanks members...
Re: Trick Flow Head Stud kit question? [Re: moparAL] #2733060
01/14/20 06:11 PM
01/14/20 06:11 PM
AndyF Offline
AndyF  Offline
If your headers have thick flanges then you'll need the correct studs on the bottom row. I ended up buying ARP studs by length since none of the kits available then had the correct parts in them.
Re: Trick Flow Head Stud kit question? [Re: AndyF] #2733063
01/14/20 06:31 PM
01/14/20 06:31 PM
moparAL Offline OP
moparAL  Offline OP
Hello Andy- I have TTI 1 7/8 inch Primaries. I think they have fairly thick flanges. May just be use bolts. But studs aren't cheap and the cost of the extra bolts you had to buy for the header flange to clear.
Re: Trick Flow Head Stud kit question? [Re: AndyF] #2733128
01/14/20 09:07 PM
01/14/20 09:07 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
If this is the case, I'll also add to see if you can work with ARP to create a proper kit for these heads for the next buyer. Sometimes it just takes the buyer to let a vendor know it's in demand.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Trick Flow Head Stud kit question? [Re: A39Coronet] #2733164
01/14/20 10:40 PM
01/14/20 10:40 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
So the best that I can tell, I used ARP part#145-4206 studs on my TF270 heads. On the dyno we ran them with my Hooker 5209 2 inch headers and did not have any fitment issues. These are the 12 point nut kits.
