Page 2 of 4 1 2 3 4
Re: Aluminum 8 3/4 center section P4876445 [Re: MR_P_BODY] #2733095
01/14/20 07:40 PM
01/14/20 07:40 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
Originally Posted by MR_P_BODY
I've been running the alum case for years without ANY issues.. twisted up one set of axles but
the case was perfect.. all very hard launches
wave
I remember your posts well Mr PBody!!! up
CrAzYMoPaRGuY
Re: Aluminum 8 3/4 center section P4876445 [Re: Thumperdart] #2733097
01/14/20 07:41 PM
01/14/20 07:41 PM
Canada
Canada
Originally Posted by Thumperdart
Been running the Dr. Diff for a few years now and love it......it's a bit heavier but well braced......
I'll take a look. Thanks!
CrAzYMoPaRGuY
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733105
01/14/20 08:11 PM
01/14/20 08:11 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
wElCoMe back cRaZy .... you going to let oleHam post now too ?
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733112
01/14/20 08:26 PM
01/14/20 08:26 PM
Locomotion Offline
Locomotion  Offline
I ran the aluminum cases for 12-14 years in my Dart Sport running mid-low 11's @ around 3,500 lbs footbraking between 1.47 and 1.53 60'.. I think it helps gear life a bit, but the ring & pinion has always been the weak point and I broke one or two and caught 1-2 in time. They were run a lot. That 11 lbs does make an obvious difference when lifting it into place! Used a steel billet yoke too.
Less ratio often means less, but bigger teeth, which are stronger.
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733123
01/14/20 09:01 PM
01/14/20 09:01 PM
AndyF Offline
AndyF  Offline
Originally Posted by CrAzYMoPaRGuY
Originally Posted by AndyF
Chat with Doctor Diff. He knows a lot about those housings. He might have his own housing out now, not sure if he made it happen or not.
I think he didn't like them, thought they were overpriced. I remember replies about 10 years? ago. They went to $900 and everybody thought wayyyyy too expensive.
10 years ago is a long time. I know that Doctor Diff has developed a bunch of 8 3/4 parts over that time. He has nodular housings available now and I know he had plans to produce an aluminum version.
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733127
01/14/20 09:06 PM
01/14/20 09:06 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Originally Posted by Doc Fiberglass
CRaZy apimp... is that 650 Canadian or USA horsepower?
US horsepower. If Canadian horsepower the conversion would bring it down to 497 horsepower but after taxes here I would be left with nothing.....
shruggy
Doesn't work that way, because Canadian kilometers are shorter than US miles, so it's still 650 hp whistling
Re: Aluminum 8 3/4 center section P4876445 [Re: dOoC] #2733140
01/14/20 09:38 PM
01/14/20 09:38 PM
Canada
Canada
I'm almost embarrassed to say.... I don't remember Oleham's posts!!! Was he race guy or general forum guy or...?
I remember YOU had an inferior motorhome.....
whistling
CrAzYMoPaRGuY
Re: Aluminum 8 3/4 center section P4876445 [Re: AndyF] #2733141
01/14/20 09:40 PM
01/14/20 09:40 PM
Canada
Canada
Looking at my combo do you have any tips Andy? Think I should be "cross your fingers" safe or do you see anything I might address??
CrAzYMoPaRGuY
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733152
01/14/20 10:03 PM
01/14/20 10:03 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
laugh2..... I remember scoring some of these on closeout at work for $200 dealer cost!
Re: Aluminum 8 3/4 center section P4876445 [Re: J_BODY] #2733158
01/14/20 10:19 PM
01/14/20 10:19 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So everything breaks at some point, in the above failure the ring pushed away from the pinion , fracturing the housing, because of large tooth breakage jamming between the R&P? work
Your pic does show well the clearance issue with large pinion lower numerical ratios up
When the Mopar Alum housing first hit the market from memory it was in the $500 range, a year or so later it went to $600 range, and last price when still offered was in $900 range.
Never heard about the $200 closeout pricing.
Re: Aluminum 8 3/4 center section P4876445 [Re: J_BODY] #2733159
01/14/20 10:20 PM
01/14/20 10:20 PM
Canada
Canada
OUCH!!!
Now that's not good
eek
CrAzYMoPaRGuY
Re: Aluminum 8 3/4 center section P4876445 [Re: jcc] #2733170
01/14/20 11:09 PM
01/14/20 11:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Back in the dark ages the parts department would get lists of overstock NS1 liquidation stuff..... that’s where we got the bare MP iron heads that reside on our “bracket Betty” mill.
I had two of the aluminum pigs... actually sold them in the classifieds ions ago for a nice profit..... certainly not stupid 1k profit though! For that kind of money get the 8.75 with the .25 upgrade smile
Just use the nodular 8.75.... at least it will contain the mayhem.
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733173
01/14/20 11:20 PM
01/14/20 11:20 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I like mine but wouldn't spend a grand on it if I was to do it again. I paid $600 for it back when they first came out what seems like almost 20 years ago now. I didn't put it in a car until a few years ago so can't say I've made 1,000s of passes while throwing tons of power at it but it's been tested.12.1-11.90s @ 110-112. 450 hp small block/904, usually around a 1.7 60 ft, around 3,200 lbs. with driver, drag radials. Plenty of street and some highway miles driven to the track, no problems except the pinon seal leaks a bit after it sits. Weight saving was pretty significant though.
Rest of the parts is basic stuff. Strange 4.10 street gears, billet 7290 yoke, all Timken bearings, Auburn sure grip, Moser axles, no backbrace.
From what I can remember the only set up problem with mine was the counterbore in the housing where the caps install into was really tight, definitely fought with that a little bit.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Aluminum 8 3/4 center section P4876445 [Re: J_BODY] #2733174
01/14/20 11:21 PM
01/14/20 11:21 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
A little Gorilla Glue should fix that right up.
CrAzYMoPaRGuY , is that 650 Morgan horses or 650 Shetland pony's???
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Aluminum 8 3/4 center section P4876445 [Re: J_BODY] #2733184
01/14/20 11:42 PM
01/14/20 11:42 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
thumbs
That's how daddy likes it. laugh2 laugh2
Re: Aluminum 8 3/4 center section P4876445 [Re: tubtar] #2733188
01/15/20 12:07 AM
01/15/20 12:07 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Old school MW Alum vs new School Mopar 8.75
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733192
01/15/20 12:18 AM
01/15/20 12:18 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
whistling
CRS ? ... that’s a illness that the eLdErY suffer from ! Luckily.., I’m quite a few years from that timetable up
That dastardly oleHam ? ... that fiberglass nose cone of a bomb making apimp who proclaimed to be living in a cardboard box sometimes in a cave in east Texazz ... was my wanna been nemesis... but I was actually his ... was jsta general poster!
Me thimks some of his posts are still up !
Re: Aluminum 8 3/4 center section P4876445 [Re: jcc] #2733194
01/15/20 12:21 AM
01/15/20 12:21 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I have a couple prototype aluminum 742 and 489 8.75" castings, but the production version is not available yet.
If you are looking for strength, I recommend my nodular iron 489 case with HD forged steel caps. Pictures of the HD version can be seen on the right side of the link, below:
https://www.doctordiff.com/8-3-4-nodular-iron-casting.html
Re: Aluminum 8 3/4 center section P4876445 [Re: CrAzYMoPaRGuY] #2733196
01/15/20 12:26 AM
01/15/20 12:26 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Save the money and get one of Dr Diffs nodular units. No way any empty 8-3/4 pig is worth $1000 no matter what it’s made of in my opinion. At that price, plus gears and everything else needed, you’re into Dana budget territory. I run a stock 742 chunk with MW steel maincaps, a 35-spline spool, and a backbrace. I’m footbraking perhaps 550hp at it in a full weight (3800-lb in the beams) B-body. It’s stood up well for a number of years, probably has at least 400 passes and plenty of street miles on it.... no issues thus far. I know 8-3/4’s have their limit, but I think if set up right, they’re a little tougher than most give them credit for.
BTW: Great to see Cass (Dr Diff) weigh in here. My housing is full of his parts and Cass has spent way more time with me on the phone helping me than my business warranted. one of the good guys for sure!! 👍
Re: Aluminum 8 3/4 center section P4876445 [Re: StealthWedge67] #2733197
01/15/20 12:30 AM
01/15/20 12:30 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
No way ? .. but how about a MAG center section ??!! eek
Page 2 of 4 1 2 3 4
