Camshaft comparison, your thoughts #2732895
01/14/20 10:31 AM
01/14/20 10:31 AM
Guitar Jones Offline OP
This is for my W200 360, Edelbrock Performer RPM, Holley 600 VS and 1.625 primary long tube headers. The truck is a stick with 4.10 gears no A/C but it does have power brakes so vacuum at idle is a concern but that can certainly be addressed with an electric pump or reservoir. I would like to be able to rev this engine to at least 6000 RPM. While there may be a stroker crank in the future and a 750 carb right now it's stuck with the low compression pistons. Would like to hear all thoughts.
Comp Nostalgia Plus ------ Howards Cams
Adv. duration 284/291 ----- 289/287
Duration at .050 239/246 - 235/243
Lift .484/.484 ------------------ .480/.488
Lobe sep. angle 108 ------- 109
The lift figures are close enough but it looks like the Comp cam has a faster rate of lift looking at the advertised and .050 lift duration figures. I'm not sure how that would affect the idle vacuum and if the 1 more degree of lobe separation angle on the Howards cam would negate any difference. Thoughts?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Camshaft comparison, your thoughts [Re: Guitar Jones] #2732922
01/14/20 12:07 PM
01/14/20 12:07 PM
an8sec70cuda Offline
I don't think there'd be any real noticeable difference b/t them.
CHIP
'06 GMC 2500HD LBZ Duramax
