question for transmission guys #2732552
01/12/20 08:07 PM
01/12/20 08:07 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
looking at a500 and a518 parts breakdown on mopar parts giant. on a500 clutches and steels are same part numbers for front and rear of one section of the overdrive unit(not 904/727 part of trans) as they are for an a518. but an a518 shows 7 and 8 clutch/steel combo, where a500 shows 5 and 6 clutch/steel combo. i am sure that i am missing something minor but don't know what. thanks in advance.
Re: question for transmission guys [Re: rbkt65] #2732573
01/12/20 09:02 PM
01/12/20 09:02 PM
Guitar Jones Offline
Both O/D units are basically the same except for the number of discs and plates for the O/D so it all sounds right to me.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: question for transmission guys [Re: Guitar Jones] #2732577
01/12/20 09:26 PM
01/12/20 09:26 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
yes i see. but where does the extra room come from to add the extra clutch/steel in an a518? that is what i am not seeing. i have a diesel 4x4 od unit that has, i think, one clutch and steel more than a gas engine.
Re: question for transmission guys [Re: rbkt65] #2732640
01/13/20 04:51 AM
01/13/20 04:51 AM
There is a thick pressure plate in that stack that that takes up the extra room.
Re: question for transmission guys [Re: Guitar Jones] #2732758
01/13/20 05:49 PM
01/13/20 05:49 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
thank you. i will look again. knew there was something i was over looking.
Re: question for transmission guys [Re: rbkt65] #2732768
01/13/20 06:31 PM
01/13/20 06:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
A500 is a 904 based front half
A518 is a 727 based front half
I dont remember the differences other than that
