Re: Cluster Gear [Re: scatpacktom] #2731915
01/10/20 06:54 PM
01/10/20 06:54 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Originally Posted by scatpacktom
So here is the bigger picture... The world is out of 18 spline clusters?
I will have more in stock at some point. Samples are approved, but it's a slow process.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Cluster Gear [Re: Dan Brewer] #2731918
01/10/20 07:03 PM
01/10/20 07:03 PM
South San Francisco, Ca
70sixpkrt Offline OP
Are you making them? What is your timeline?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Cluster Gear [Re: 70sixpkrt] #2732086
01/11/20 10:57 AM
01/11/20 10:57 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Yes. No ETA right now.
Re: Cluster Gear [Re: Dan Brewer] #2732154
01/11/20 03:25 PM
01/11/20 03:25 PM
Cool. up
Let's put it this way, I called 18 Mopar parts suppliers and they didn't have any. I also talked to a heavy hitter Super Stock racer and he had 10 NOS but were all spoken for. whiney
4-speed
3:54 Dana
Re: Cluster Gear [Re: 70sixpkrt] #2732527
01/12/20 06:18 PM
01/12/20 06:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
looks like a trans I disassembled with ATF in it whistling Just not enough lube for that position in the transmission IMHO there is a lot of load on that part of the cluster.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Cluster Gear [Re: fourgearsavoy] #2732529
01/12/20 06:26 PM
01/12/20 06:26 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Hmm... Mother Mopar did recommend ATF in colder climates for the 833.
Maybe not on a heavily loaded 18-spline trans though? popcorn
Re: Cluster Gear [Re: fourgearsavoy] #2732536
01/12/20 07:33 PM
01/12/20 07:33 PM
I've always ran straight ATF in all of my 833, street or drag racing only shruggy
Re: Cluster Gear [Re: Cab_Burge] #2732688
01/13/20 12:32 PM
01/13/20 12:32 PM
I've been using Passon Perf trans fluid for the last 7 years. It's his special concoction. It's red and like ATF fluid. I switched to Sta-lube GL4 Gear lube about 6months ago.
4-speed
3:54 Dana
Re: Cluster Gear [Re: 70sixpkrt] #2732775
01/13/20 06:48 PM
01/13/20 06:48 PM
Looks like I found an NOS cluster gear with its original cosmoline grease in its original cylinder that was sitting on a shelf collecting dust. Got lucky on finding it and the price. smile
4-speed
3:54 Dana
Re: Cluster Gear [Re: 70sixpkrt] #2732806
01/13/20 09:13 PM
01/13/20 09:13 PM
So Cal
Sinitro Online content
Sinitro  Online Content
So Cal
Wow!!!!
Nice find!!!
Just my $0.02... wink
