Re: Id this vgate shifter?
[Re: Headhunter22]
#2732303
01/11/20 11:35 PM
01/11/20 11:35 PM
Posts: 1,817 South Bend
John Brown
South Bend
Can't the levers on the tranny be put on the other way around to make it a more normal shift pattern?
[Re: Headhunter22]
#2732525
01/12/20 06:08 PM
01/12/20 06:08 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well the three levers and no extra lever off the side tell me it's made for a Nash 5 speed. Looks like a very early Long shifter built by Leonard Long himself. What gear it goes into by push or pull is determined by the position of the levers on the transmission. Now I have seen this type of shifter mounted on the front of a Nash when used in an altered or or some other weird cars they used to build back in the day. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
