Fort Worth TX - 426 Hemi Valve Seal Replacement #2730538
01/06/20 01:18 PM
01/06/20 01:18 PM
CrazyD Offline OP
CrazyD  Offline OP
Any recommendations on a reputable mechanic in Fort Worth area that can replace valve seals on a 426 hemi. Prefer old Mopar savvy mechanic that is familiar with Hemi.
Thanks!
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: CrazyD] #2731005
01/08/20 08:18 AM
01/08/20 08:18 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Sorry, most of the metroplex Mopar guys I know are wedge guys, but if you want the number of a guy who I trust and who did my machine work for 20+ years just let me know and I'll see if he's interested in HEMI work. I'm assuming they are original type iron heads?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: RapidusMaximus] #2731006
01/08/20 08:25 AM
01/08/20 08:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you want to bring it up to the Tulsa area this guy does lots of hemi and Mopar stuff. Wayne Smothers http://www.smotherssupercars.com
68 Barracuda Formula S 340
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: Bad340fish] #2731013
01/08/20 09:06 AM
01/08/20 09:06 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Looking for a old school hemi mechanic is not as easy as it used to be . Lol. They’re all dying off. I’ve got several guys that bring there cars to me all the way to Abilene from the Dallas area. I’ve worked on Hemis but I’ve never tried to change the valve seals on one in the car. It may be hard to change out the exhaust seal with the proximity to the inner fender and angle of the valve. Depends upon the spring pressure as well. My tool may be tool tall to get in there. I don’t have a hemi car in the shop to look at to measure. The problem I run into on these cars now days is that a customer brings in a car for something simple and because of the previous work of another person, there are way more things wrong than initially thought. There are some real hacks out there. Throw in just the age and mileage on the car and you have a drawn out project. These cars weren’t that well engineered in the first place and things go wrong.
What makes you think you need valve seals? Smoking when you first crank it up or can you see pieces of them laying in the head?
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: fastmark] #2731025
01/08/20 10:06 AM
01/08/20 10:06 AM
CrazyD Offline OP
CrazyD  Offline OP
Slight blue smoke one tailpipe at start, runs clean otherwise. Wary of letting someone inexperienced getting in there and causing additional issues.
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: CrazyD] #2731092
01/08/20 02:07 PM
01/08/20 02:07 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
On a Hemi I doubt that is caused by valve seals, BUT I could be wrong.
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: CSK] #2731180
01/08/20 06:13 PM
01/08/20 06:13 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I'm not going to swear it's valve seals. But if it is, it's an easy fix. If the engine is not too old, and was well put together, I wouldn't do it in the car. It's pretty easy. You just take off the heads, replace the seals, and put the heads back on. I've done it, and been done before noon.
2011 Drag Pak Challenger
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: rickseeman] #2731209
01/08/20 07:14 PM
01/08/20 07:14 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I would do a leak down test first before I just started replacing stuff.
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: fastmark] #2731214
01/08/20 07:31 PM
01/08/20 07:31 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I thought valve seals were when it smokes when you let off the gas.
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: CrazyD] #2731224
01/08/20 08:04 PM
01/08/20 08:04 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You wanting to do this with the heads still on the engine? If so, very few people have a tool to do that.
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: fastmark] #2731226
01/08/20 08:08 PM
01/08/20 08:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by fastmark
Looking for a old school hemi mechanic is not as easy as it used to be . Lol. They’re all dying off. I’ve got several guys that bring there cars to me all the way to Abilene from the Dallas area. I’ve worked on Hemis but I’ve never tried to change the valve seals on one in the car. The problem I run into on these cars now days is that a customer brings in a car for something simple and because of the previous work of another person, there are way more things wrong than initially thought. There are some real hacks out there. Throw in just the age and mileage on the car and you have a drawn out project.
Had one (customer) just this week that fit your commentary to a T. He had the car flat bedded in from another local shop. He had taken it to them for a flat spot in the carb. After 3 attempts he couldn't even make if 4 blocks without severely overheating and the flat spot was still there. We corrected those issues and several others.Also We had well over 40 hours in it and he whines about the bill (2400.00). If I hadn't been so detailed about the issues we found and the repairs we made I would have put it back exactly the way it was and told him to pick it up. panic
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: TJP] #2731232
01/08/20 08:17 PM
01/08/20 08:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My Street Hemi had the OP symptoms after a rebuild.
Found some high-temp silicone umbrella-type seals from SilverSeal in MI, installed them with the motor & heads in the car, cured.
Yup, not a walk in the park; got a valve-spring tool from Landy, and reconfigured it to work in the car.
$60/hour for mech labor? That's cheap!
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: fastmark] #2731255
01/08/20 09:19 PM
01/08/20 09:19 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
ho ya
got one last week for a cam change , block an heads are at the machine shop now !
owner said 14,000 miles on rebuild !
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: calrobb2000] #2731333
01/09/20 08:54 AM
01/09/20 08:54 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Originally Posted by calrobb2000
ho ya
I’ve got two 440’s in just like that. One bud bought a 69 4 speed car that had a cast crank motor rebuilt and a neutral balance flywheel on it. Of coarse it had a bad vibration. Pulled it apart to try and change the crank and it just needed too much work. We’re going to start over with a better build instead of fixing this one. The other cam in for a cam change. That motor had very cheap cast pistons installed too tight, rods backwards, heads done wrong. I don’t remember there being so many hacks out there years ago.
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: topside] #2731560
01/09/20 08:12 PM
01/09/20 08:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I think the guy is just a tight --s wanting something for nothing. I really wish i could put the car back to what it was when it came in. But that's not possible at this point. beer
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: CrazyD] #2732302
01/11/20 11:33 PM
01/11/20 11:33 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Thanks!
You might call Tony Cowell in Hudson Oaks a call if you haven't found someone. He is a SS racer and works on several Stocker drag cars, street rods, hot rods, etc. (817) 341-1602
Floyd Lippencott IV
Re: Fort Worth TX - 426 Hemi Valve Seal Replacement [Re: rickseeman] #2732635
01/13/20 02:05 AM
01/13/20 02:05 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Yes on intake valves then !
