Cluster Gear #2731075
01/08/20 12:52 PM
01/08/20 12:52 PM
South San Francisco, Ca
70sixpkrt Offline OP
My buddy is rebuilding my 18 spline transmission and found this inside the 1st gear cluster gear. Inside the bore it's starting to flakey/scale. What would cause this?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Cluster Gear [Re: 70sixpkrt] #2731098
01/08/20 02:15 PM
01/08/20 02:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
"Metal spalling is a process of metallic surface failure in which the metal is broken down into small flakes (spalls) from a larger solid body. This process occurs for many reasons, such as when another material impacts it at a high speed resulting in chipping the material, or due to corrosion, weathering, cavitation or excessive rolling pressure."
Re: Cluster Gear [Re: John_Kunkel] #2731124
01/08/20 03:09 PM
01/08/20 03:09 PM
Can you please put that in layman's language? Are you saying normal wear and tear since I used to race and bang the gears?
4-speed
3:54 Dana
Re: Cluster Gear [Re: 70sixpkrt] #2731129
01/08/20 03:26 PM
01/08/20 03:26 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
It's broke
Re: Cluster Gear [Re: 70sixpkrt] #2731138
01/08/20 03:56 PM
01/08/20 03:56 PM
It's worn out shruggy
Not unusual if it was ran low on lube or had sit a long time twocents
I've seen that on the tip of a output shaft, I ended up having a old time aircraft machinest weld it up with stelite rod and turn it back down to size and ran it shruggy
Not sure if that is the solution for that gear or not, probably not work
Re: Cluster Gear [Re: Cab_Burge] #2731181
01/08/20 06:16 PM
01/08/20 06:16 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
A flake of metal debris in those rollers would have made quick work of that.
Re: Cluster Gear [Re: 70sixpkrt] #2731276
01/08/20 10:23 PM
01/08/20 10:23 PM
I think if it was mine I would call Brewers and ask if anyone has a sleave to repair that.
Re: Cluster Gear [Re: GomangoCuda] #2731286
01/08/20 11:10 PM
01/08/20 11:10 PM
Already did. No. Brewers and Passon Perf doesn't have any. I'm looking for a new one and nobody has any.
4-speed
3:54 Dana
Re: Cluster Gear [Re: 70sixpkrt] #2731304
01/09/20 01:56 AM
01/09/20 01:56 AM
New York, USA
Chargerfan68 Offline
New York, USA
Try Brian at SK speed in Lindenhurst, NY. You might be very surprised. smile
Re: Cluster Gear [Re: Chargerfan68] #2731330
01/09/20 08:43 AM
01/09/20 08:43 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
How did the roller bearings look at that position. I bet you could pick them out of the pile that fell out of the cluster gear. That’s the low gear end of the shaft. Must have been lots of pressure applied there.
Re: Cluster Gear [Re: GomangoCuda] #2731334
01/09/20 08:55 AM
01/09/20 08:55 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
You may have to go to a precision machine shop in your area to look at it. I wonder if you could take a cut out in the bearing to remove the damage and go with slightly larger rolling elements. I'd worry about a sleeve on the inside as it may weaken the tube some. Though looking at the pictures, there is a lot of meat there. So a sleeve properly installed could work. But I think that repair is beyond most automotive restoration and machine shops. I think you are into high end industrial repair shops. Hopefully the cost doesn't outweigh the replacement.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Cluster Gear [Re: RoadRunner] #2731356
01/09/20 10:21 AM
01/09/20 10:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Here's a thought ... install a bronze bushing in there (just that one location - not the whole cluster) and run thinner lube in the trans.
Re: Cluster Gear [Re: Chargerfan68] #2731363
01/09/20 10:39 AM
01/09/20 10:39 AM
Will call. Thanks. No dice on SK speed. Brian is a lot of knowledge. He said to put it back together until I find one. There were no problems except for a little popping out of first gear. That's not related to the cluster gear.
4-speed
3:54 Dana
Re: Cluster Gear [Re: 70sixpkrt] #2731425
01/09/20 02:03 PM
01/09/20 02:03 PM
New York, USA
New York, USA
Well, it was worth a shot. I got a bunch of Nos 833 stuff from him over the years and his collection was staggering. The popping out of gear is most likely angle worn dog teeth on the gear, as he probably told you. Did you ask if he had an nos 1 st gear?
Re: Cluster Gear [Re: Stanton] #2731430
01/09/20 02:11 PM
01/09/20 02:11 PM
No way in the world would I even think of putting needle bearings in the cluster gear against a bronze bushing, no way tsk
I don't know what exactly the heat treat is on those gears and the other gears in the NP833 but I'll bet they are really hard, same thing on the needles bearings and roller bearings work
I would look into seeing if there is a material good enough to make a repair insert( that would have to be press in with the proper interference fit to keep it from spinning when hot) in it though scope twocents
OP, your pursuing the best bet,, a new NOS gear up
What does the cluster gear shaft look like on that end?
Re: Cluster Gear [Re: Cab_Burge] #2731442
01/09/20 02:28 PM
01/09/20 02:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I think a bronze bushing is the most practical solution, not needle bearings on the bronze bushing but a bushing directly on the shaft. The gears are case hardened so boring the gear would involve grinding rather than boring with a tool bit.
Re: Cluster Gear [Re: John_Kunkel] #2731452
01/09/20 02:44 PM
01/09/20 02:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
WHERE did I say anything about needle bearings ?!?!? Install a bronze bushing in that one location INSTEAD OF needle bearings - it saves the cluster at least !!
Re: Cluster Gear [Re: Cab_Burge] #2731464
01/09/20 03:16 PM
01/09/20 03:16 PM
The gear shaft does not too bad. Just some wear. I ordered a new shaft anyway. The tranny has a new 1st, 2nd, and 3rd gear in it already from my last rebuilt 15 years ago. They look excellent. He said the popping/sliding out of 1st is probably something else. I also have a new 1-2 hub assembly. It's going to be put back together with the new shaft and 1-2 hub assembly and wait until I find a cluster gear.
4-speed
3:54 Dana
Re: Cluster Gear [Re: 70sixpkrt] #2731805
01/10/20 03:00 PM
01/10/20 03:00 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
So here is the bigger picture... The world is out of 18 spline clusters?
Re: Cluster Gear [Re: scatpacktom] #2731854
01/10/20 04:27 PM
01/10/20 04:27 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Is Liberty Gear still in business? They maybe able to fix the cluster. Just a thought. http://libertysgears.com/
