Re: Cluster Gear
[Re: scatpacktom]
#2731915
01/10/20 06:54 PM
01/10/20 06:54 PM
Posts: 766 Ohio
Dan Brewer
Ohio
So here is the bigger picture... The world is out of 18 spline clusters? I will have more in stock at some point. Samples are approved, but it's a slow process.
Re: Cluster Gear
[Re: Dan Brewer]
#2731918
01/10/20 07:03 PM
01/10/20 07:03 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
So here is the bigger picture... The world is out of 18 spline clusters? I will have more in stock at some point. Samples are approved, but it's a slow process. Are you making them? What is your timeline?
Re: Cluster Gear
[Re: 70sixpkrt]
#2732527
01/12/20 06:18 PM
01/12/20 06:18 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
looks like a trans I disassembled with ATF in it Just not enough lube for that position in the transmission IMHO there is a lot of load on that part of the cluster. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Cluster Gear
[Re: 70sixpkrt]
#2732806
01/13/20 09:13 PM
01/13/20 09:13 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Wow!!!! Nice find!!! Just my $0.02...
