Page 33 of 48 1 2 31 32 33 34 35 47 48
Re: Modern Bullitt build [Re: T2R9] #2720562
12/01/19 06:26 AM
12/01/19 06:26 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Originally Posted by T2R9
Wow,nice work! This whole build is perfection!
Agreed, simply stunning work quality and photography.
Keep it up Pat!
Re: Modern Bullitt build [Re: larry4406] #2722413
12/07/19 09:53 PM
12/07/19 09:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Only 1 spot for a temperature sender on this gen3 Hemi, and I need two, 1 for the fuel injection and 1 for the gauge. I had to remove a freeze plug and make a plate that I could drill for an additional temperature sender.
I also have all of the wiring set and ready to enter and pass through the firewall through a split grommet. This will allow all of the plug-in connectors to pass through a single 2 1/4ā€ hole hidden just above the transmission.
Pat
[Linked Image]post pictures
Re: Modern Bullitt build [Re: Keepat] #2722465
12/08/19 08:35 AM
12/08/19 08:35 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - very clever solution to adding another temperature port! Excellent work and photo's as well.
Re: Modern Bullitt build [Re: larry4406] #2722471
12/08/19 09:28 AM
12/08/19 09:28 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir!
Re: Modern Bullitt build [Re: Keepat] #2722668
12/08/19 11:40 PM
12/08/19 11:40 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Engine is installed (I hope for the last time;-)
Pat
[Linked Image]images free hosting
[Linked Image]upload picture without account
[Linked Image]pic upload
Re: Modern Bullitt build [Re: Keepat] #2722672
12/08/19 11:54 PM
12/08/19 11:54 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
That's awesome! Very nice work! You should be extremely pleased. -Trent
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Modern Bullitt build [Re: Keepat] #2722696
12/09/19 07:56 AM
12/09/19 07:56 AM
Medford OR
FrankenScamp Offline
Medford OR
Lots of progress lately....very cool!
Looks great. bow
Re: Modern Bullitt build [Re: FrankenScamp] #2722699
12/09/19 08:23 AM
12/09/19 08:23 AM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
Love the body lift you are using..
Looking for affordable Cuda parts
Re: Modern Bullitt build [Re: MadMopars] #2725713
12/20/19 07:50 PM
12/20/19 07:50 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Trent,
It is definitely the part of the build
Thank you!
Pat
Re: Modern Bullitt build [Re: FrankenScamp] #2725714
12/20/19 07:51 PM
12/20/19 07:51 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Looks great. bow
Thank you!
Re: Modern Bullitt build [Re: rocksmopar] #2725715
12/20/19 07:55 PM
12/20/19 07:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Yes, a must have for the middle aged ;-)
Re: Modern Bullitt build [Re: Keepat] #2725716
12/20/19 07:55 PM
12/20/19 07:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Moving along with a few projects! All the fuel, AC, and Hydroboost lines hooked up! Trans cross member and shifter is installed.
Pat
[Linked Image]i want you forever
[Linked Image]photoupload
[Linked Image]pic sharing
Re: Modern Bullitt build [Re: Keepat] #2727001
12/26/19 10:10 AM
12/26/19 10:10 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Emergency brake cables installed using a small stainless steel roller that I got from West Marine. It guide the E brake cable after it passes through the sub frame connector.
Pat
[Linked Image]upload free photos
Re: Modern Bullitt build [Re: Keepat] #2727506
12/27/19 08:43 PM
12/27/19 08:43 PM
Superfreak
Superfreak
I can honestly say that the quality of your work is absolutely outstanding!!!
Re: Modern Bullitt build [Re: ] #2727604
12/28/19 09:26 AM
12/28/19 09:26 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Agreed! I think this is one of the best builds out here on net.
Re: Modern Bullitt build [Re: larry4406] #2728175
12/29/19 11:55 PM
12/29/19 11:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you gentlemen!
Not a fun weekend installing the rear glass and trim. AMD glass was not a problem but fitting the trim took two or three times to get everything just right. Fortunately no chips or scratches just a lot less hair on my head ;-)
Pat
[Linked Image]image sharing
Re: Modern Bullitt build [Re: Keepat] #2730147
01/05/20 12:14 AM
01/05/20 12:14 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Car is ready for fuel! Had to make a tool for the original theft proof fasteners.
Pat
[Linked Image]photo hosting site free
[Linked Image]old sawmill cafe
Re: Modern Bullitt build [Re: Keepat] #2730626
01/06/20 08:14 PM
01/06/20 08:14 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Weld Mount is in acrylic adhesive mounting system with a wide variety of very cool fasteners. We use it on the boats when we cannot drill into a bulkhead, fuel tank, or hull sides to mount or fasten equipment and wires. I used it to mount a few fan relays and headlight door operator To keep the engine bay clean of fasteners. Very cool stuff, easy to use an extremely strong!
Pat
http://weldmountsystems.com/
[Linked Image]free image url
common american girl first names
Re: Modern Bullitt build [Re: Keepat] #2730680
01/06/20 11:39 PM
01/06/20 11:39 PM
Medford OR
Medford OR
Iā€™m going to start saving up now, for a plane ticket to Maryland to see this car when it is done.
Thanks, again, for the update. Cheers. šŸ‘
Re: Modern Bullitt build [Re: FrankenScamp] #2730869
01/07/20 05:45 PM
01/07/20 05:45 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
I know I want to see it and thank god I am only one state away!
