Do Hemi rockers lose their ratio over time?
#2636960
03/25/19 01:09 PM
03/25/19 01:09 PM
Posts: 36 Aubigny, MB Canada
69 F5 R/T
Aubigny, MB Canada
One of the strangest searches I've done, stock rocker ratio's of the 426 Hemi.
Is there some mystery I'm missing to all of this? I had thought it was 1.56 intake 1.53 exhaust (no clue where I got that over the years) but now that I started searching for it, I find practically nothing, other than more modern or A/M rocker ratios.
And also this piece of info from this forum;
"The valvetrain geometry on the 426 Hemi is the most ... ROCKER RATIO The stock Hemi rocker ratios are in the 1.5 to 1.56 area. "
"The ratio of these rockers is same as factory 1.57 / 1.53 . True actual ratio from factory and on these is actually lower. "
Links to info no longer available.
So what's the deal? Were the tolerances in manufacturing so bad that there is no consensus on what the stock ratios are?
Or do those long, thin spider leg rockers, slowly Change ratio over time and when running larger cams ect…………
Reason I'm asking is we just dialed in the Erson 278/370 solid roller cam and with 370 lobe lift plus 1.50 rocker ratio we should be about 555 lift and we are at 525 lift on the intake. (was originally hoping for the 1.56 # which would have been 577!)
Could the rocker ratio be below 1.5?
Bringin Back the Iron!
Re: Do Hemi rockers lose their ratio over time?
[Re: 69 F5 R/T]
#2636964
03/25/19 01:36 PM
03/25/19 01:36 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
Yes, they vary a lot. Stock rockers will be all over the place as far as the actual ratio. You can have them corrected, but you're better off buying new roller rockers from somewhere like Stage V.
[Re: 69 F5 R/T]
#2636972
03/25/19 01:48 PM
03/25/19 01:48 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
I'm about to start looking at this and don't have the answer but I can tell you the pushrod angle alone steals it's share of lift, as any deviation from a straight line coming off the lifter results in a loss.
The more I study these, the more I realize the guys who put in .750 (theoretical) rollers back in the day....unless their rockers were reworked of course.... I'd be willing to bet some had around .650 net lift once the lash and loss from rocker ratio + pushrod angle was considered.
I don't think the iron rockers can bend enough to lose ratio as described, I believe they would break first.
Rich H.
Esse Quam Videri
[Re: an8sec70cuda]
#2637017
03/25/19 04:00 PM
03/25/19 04:00 PM
Posts: 2,692 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Yes, they vary a lot. Stock rockers will be all over the place as far as the actual ratio. You can have them corrected, but you're better off buying new roller rockers from somewhere like Stage V. I agree with this.
2011 Drag Pak Challenger
[Re: lewtot184]
#2637040
03/25/19 04:47 PM
03/25/19 04:47 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
Is that with zero lash ??? you said it was a solid. the lash is taken off the gross lift #.
[Re: lewtot184]
#2637041
03/25/19 04:48 PM
03/25/19 04:48 PM
69 F5 R/T
Aubigny, MB Canada
did you measure the lobe to make sure it actually was .370? No, and I Kick myself now for not doing that!!! Just shows, gotta cover All the bases! I did check duration and it was right on the money with what it's supposed to be.
[Re: lewtot184]
#2637044
03/25/19 04:52 PM
03/25/19 04:52 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’ve never checked any hemi rockers myself, but I’ve heard from a few people who have that they can actually be as bad as the 1.3x’s. You’re not too far off from that....... .525 at the valve with a .370 lobe is an effective RR of 1.41.
Hemi rockers that are actually 1.57in/1.52ex as taken from a production engine as delivered from Ma Mopar are probably even rarer than 906 heads that came from the factory with anything even close to 79.5cc chambers.
[Re: 69 F5 R/T]
#2637104
03/25/19 07:42 PM
03/25/19 07:42 PM
Posts: 43,368 Bend,OR USA
Cab_Burge
I use to race a Street Hemi in NHRA stock, I decided to check the valve lift at the valve retainers so I wouldn't get thrown out for to much lift on a 1970 street hemi Cuda. What I found was that the ratio where no where close to each other in 2 and half sets of stock rocker arms ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) The intakes varied from .430 to .510 net lift (.464 was legal, I think) at the retainers using checking springs and solid lifter set at zero lash and the exhaust rocker arms varied worst than the intake rockers did ![down down](/ubbthreads/images/graemlins/custom/down.gif) I use a old Racer Brown cheater cam on the driver side of the motor and the same pushrods and rocker setting on all of them with the same dial indicator set up on the same angles and relation ship the valve stem angles on the same head ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) BTW, I saw 4.0 CC variance on the four combustion chambers on that head also ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif)
[Re: CSK]
#2637196
03/25/19 11:38 PM
03/25/19 11:38 PM
69 F5 R/T
Aubigny, MB Canada
Is that with zero lash ??? you said it was a solid. the lash is taken off the gross lift #. Yep, that's adding the .012 to the #. Which reminds me, need to call Erson and see what they recommend for lash. This is the way it was set from engine builder.
[Re: Cab_Burge]
#2637198
03/25/19 11:39 PM
03/25/19 11:39 PM
69 F5 R/T
Aubigny, MB Canada
I use to race a Street Hemi in NHRA stock, I decided to check the valve lift at the valve retainers so I wouldn't get thrown out for to much lift on a 1970 street hemi Cuda. What I found was that the ratio where no where close to each other in 2 and half sets of stock rocker arms ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) The intakes varied from .430 to .510 net lift (.464 was legal, I think) at the retainers using checking springs and solid lifter set at zero lash and the exhaust rocker arms varied worst than the intake rockers did ![down down](/ubbthreads/images/graemlins/custom/down.gif) I use a old Racer Brown cheater cam on the driver side of the motor and the same pushrods and rocker setting on all of them with the same dial indicator set up on the same angles and relation ship the valve stem angles on the same head ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) BTW, I saw 4.0 CC variance on the four combustion chambers on that head also I was just about to do the same over the next cpl days, but scared of what I might find!
[Re: Cab_Burge]
#2637277
03/26/19 10:10 AM
03/26/19 10:10 AM
69 F5 R/T
Aubigny, MB Canada
I know the tips on Brents all looked reworked and machinist wasn't too pleased with them.
Makes me wonder how many of these issues are from them being messed with or band aided build after build...…..
[Re: racerlall]
#2730352
01/05/20 05:36 PM
01/05/20 05:36 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Bringing this back from the dead.
Maybe not good ideas but what if you ran through and tested each rocker ratio and......
-Had the cam ground with each lobe matched to that particular rocker ratio. Not perfect but could get them closer.
-Have rocker adjusters made with an offset ball. Would take some trial/error to achieve the right offset and valve lash but maybe could have some offset closer/further away to equalize ratios.
To that point, has anyone tested adjuster concentricity?
[Re: INTMD8]
#2730485
01/06/20 10:27 AM
01/06/20 10:27 AM
rickseeman
Stuttgart, Arkansas
I feel it would be a better idea to throw that garbage in the landfill and get some Stage V rockers.
[Re: rickseeman]
#2730498
01/06/20 11:16 AM
01/06/20 11:16 AM
INTMD8
Lake Villa Il
Completely agree that would be better.
Would also be better to put the entire iron engine in the landfill and use better parts entirely, was just thinking about how to make this a bit better without spending thousands on a rocker system. (since I need to order a cam anyway)
[Re: INTMD8]
#2730508
01/06/20 12:09 PM
01/06/20 12:09 PM
ZIPPY
S.E. Michigan
Well, I checked what I could and identified what's what within this context, but in this few batches of exhaust rockers I had to work with I never found anything worse than 1.49 or better than 1.56.
I haven't worked with a whole bunch of these for my whole life or anything, and have only done whatever it is I have done, and found what I found.
In my humble opinion...as stated earlier, I really feel they would break before losing ratio over time.
I would have to guess that the folks who rework old rockers and change the ratio....most likely accomplish that by relocating the adjuster.
Rich H.
Esse Quam Videri
