sway bar suggestions for 69 charger #2728908
01/01/20 11:24 AM
01/01/20 11:24 AM
moparx Offline OP
moparx  Offline OP
what would be your suggestion for front and rear sway bars for a stock front suspension, +2" arch rear spring, 69 charger ?
no other plans for suspension.
RB/727 combo.
215-70 front, and 12.50 rear tires. no planned changes there as well.
does 1 1/4 and 7/8 sound about right ?
poly or rubber end links ?
not going to autocross or top speed twisties. just reduce some body lean in the corners.
TIA. bow
beer
Re: sway bar suggestions for 69 charger [Re: moparx] #2728998
01/01/20 02:36 PM
01/01/20 02:36 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Years ago I did 1 1/4 front & 3/4 rear bars on a '70 Satellite wagon that was optioned like a Road Runner.
Had 14x7 Magnums & 225/70s all around. More rear weight than sedan bodies.
It was pretty capable & neutral, surprised a few folks.
Your combo sounds tire-limited in front, as in "push"/understeer.
Less deflection with poly; deflection detracts from a bar's effectiveness, of course.
Might want to look for an adjustable 7/8 rear bar so you can dial it in better.
Re: sway bar suggestions for 69 charger [Re: moparx] #2729200
01/01/20 11:32 PM
01/01/20 11:32 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I've got a '65 big block, power steering, Satellite hardtop w 225/70 BFG T/A's on Ford 14x6.5 steelies all around.
In front, I installed a 1-1/8" tubular bar. In back installed a 3/4" bar with +1-1/2" arch.
Poly bushings on all the sway links. OEM rubber everywhere else.
For shocks I chose Monroe Matics in front and Monroe Gas-Matics in rear, so the rear is slightly stiffer shocked.
It behaves the way I like it..
Less understeer than stock, turns much flatter without adding harshness, so very streetable.
Stays neutral, but ultimately oversteers at the limit, and the oversteer can be brought on w throttle.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: sway bar suggestions for 69 charger [Re: 67SATisfaction] #2729288
01/02/20 10:52 AM
01/02/20 10:52 AM
moparx Offline OP
moparx  Offline OP
thanks for the confirmation of my thoughts guys ! up
was thinking of using poly pivot bushings with the grease fitting in the brackets as well.
beer
Re: sway bar suggestions for 69 charger [Re: moparx] #2729348
01/02/20 02:10 PM
01/02/20 02:10 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
IMO, on our Mopars, its always best to pick/install a TB package first and road test, and THEN decide on a front swaybar if needed, and THEN decide on a rearbar to fix the wrong size front swaybar ,to regain balance. biggrin
And note, NOBODY has yet reported they picked to large of a TB. ( Ok, I'm sure somebody has, but in most cases, most wonder if they went big enough after installing, but everybody is at least partially happier with any bigger TB)
Re: sway bar suggestions for 69 charger [Re: moparx] #2729350
01/02/20 02:14 PM
01/02/20 02:14 PM
A collage of whims
A collage of whims
^^^ Yup.
In technical terms:
I'm sure you've seen old rubber swaybar bushings all mooshed out of their brackets, from accumulated deflection over time...
Re: sway bar suggestions for 69 charger [Re: moparx] #2729369
01/02/20 03:36 PM
01/02/20 03:36 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Bigger TBs would help with lean, dive, lift... and the sway bar would then be used a s a tuning device.
Re: sway bar suggestions for 69 charger [Re: moparx] #2729416
01/02/20 05:49 PM
01/02/20 05:49 PM
Albany, NY
Albany, NY
Yes, this is what my swaybar kits came with. Maybe they all do. I don't think the OEM setup is this way.
I specifically chose to keep most of the suspension stock with a lot of OEM rubber to reduce harshness, since my '65 Satellite is primarily a street car.
- Art
Re: sway bar suggestions for 69 charger [Re: 67SATisfaction] #2729636
01/03/20 12:47 PM
01/03/20 12:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
If should be noted here any swaybar mounting induced "harshness" can only be transmitted into the chassis when that axles wheels are moving different directions/speeds vertically, ie a speed bump driven straight over will not cause any additional or less perceived "harshness" based on the swaybars chosen mounting configuration.
Re: sway bar suggestions for 69 charger [Re: moparx] #2729879
01/04/20 03:43 AM
01/04/20 03:43 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I really like the Hotchkis sway bars on my 68 Charger, the rear bar mounts with existing holes, VERY easy to install & is adjustable.
Re: sway bar suggestions for 69 charger [Re: CSK] #2730238
01/05/20 12:24 PM
01/05/20 12:24 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Switching to 1.03 TB's was the best first step I made on my B&E bodies, the difference in handling was great. On my 'Cuda I used the Hellwig 1.25 tubular front swaybar and the handling really improved! There was no downside, ride is smooth, body lean gone. The next major improvement you can make is a modern performance tire, T/A radials are not even close! Since I run 13" front discs, I had to go with a 17" rim, if you get a performance tire that is around 27" tall, 90% of folks don't realize it is a bigger wheel, It looks right. This is just my experience for a street driven, non-rally, muscle car.
Re: sway bar suggestions for 69 charger [Re: jcc] #2731606
01/09/20 10:30 PM
01/09/20 10:30 PM
Albany, NY
Albany, NY
..this is why it was my choice to use poly bushings on my sways, but kept OEM rubber everywhere else..
- A
