426 hemi dual plug heads p4120960 #2550360
09/15/18 05:38 PM
09/15/18 05:38 PM
st.louis,mo.
dart games Offline OP
st.louis,mo.
cant find this number anywhere on the web,can someone id these heads,numbers on them are p4120960,426 hemi dual plug
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2550445
09/15/18 10:21 PM
09/15/18 10:21 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Dart
2011 Drag Pak Challenger
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2550541
09/16/18 07:50 AM
09/16/18 07:50 AM
st.louis,mo.
st.louis,mo.
thanks rick
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2550569
09/16/18 11:36 AM
09/16/18 11:36 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
These are dart castings from the late 70's early 80's.Do yours look like these?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2550574
09/16/18 11:42 AM
09/16/18 11:42 AM
hemi-itis Offline
hemi-itis  Offline
Had mine on a shelf in the garage for over 25 years.Finally put them on last year!
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2550576
09/16/18 11:50 AM
09/16/18 11:50 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
That looks Sweet Hemi-itis... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2550596
09/16/18 12:52 PM
09/16/18 12:52 PM
A727Tflite Offline
A727Tflite  Offline
Hemi-itis - have any flow numbers from yours ?
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2550666
09/16/18 04:25 PM
09/16/18 04:25 PM
hemi-itis Offline
hemi-itis  Offline
Never had them flowed,Might be able to get them from Steve Sanchez.
That are fueler heads from back in the day........
They work GREAT! smoke
Re: 426 hemi dual plug heads p4120960 [Re: rickseeman] #2729850
01/03/20 10:58 PM
01/03/20 10:58 PM
florida usa
cudame Offline
cudame  Offline
florida usa
I THOUGHT THEY DIDN'T MAKE DART HEADS SOMEONE TOLD ME THAT ARE YOU SURE
Re: 426 hemi dual plug heads p4120960 [Re: cudame] #2729884
01/04/20 05:40 AM
01/04/20 05:40 AM
st.louis,mo.
st.louis,mo.
i have dart heads on this motor,looking for dual plug mullens heads
Re: 426 hemi dual plug heads p4120960 [Re: cudame] #2730002
01/04/20 02:32 PM
01/04/20 02:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
Some body misinformed you on Dart not having their own aluminum hemi head castings, it wouldn't surprise me that they had more than one dual plug casting number heads also shruggy scope
I assembled a blown street hemi motor for a customer in SO CA back in the mid 1990s that had a set of those heads, his family owned several Dodge dealerships and furnished all the parts, he bought those heads form Direct Connection along with a KB street hemi block shruggy
Re: 426 hemi dual plug heads p4120960 [Re: cudame] #2730150
01/05/20 12:27 AM
01/05/20 12:27 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Come on dude. They were even in the MP catalog.
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2730152
01/05/20 12:35 AM
01/05/20 12:35 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I assume you mean 433 heads? AKA twin plug heads, AKA replacement heads, AKA Ross Foundry heads. Mullens was a head porting shop. They ported most of the top hemi heads for a long time. I feel you will make more power with the heads they make today.
Re: 426 hemi dual plug heads p4120960 [Re: rickseeman] #2730169
01/05/20 03:26 AM
01/05/20 03:26 AM
iagree up
Re: 426 hemi dual plug heads p4120960 [Re: Cab_Burge] #2730171
01/05/20 03:38 AM
01/05/20 03:38 AM
st.louis,mo.
st.louis,mo.
hemi -itis,same heads as mine,has total flow on them,after i look them up,says dart made them,thats what i have,but on my header flange can only get 4 bolts to line up in them,im sure its a old fuel heads,they work though ,there not like the 433 heads
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2730293
01/05/20 02:35 PM
01/05/20 02:35 PM
One set of heads I've used from Dart where the D4 heads, I was not impress with the results on that motor with those heads down
I don't remember the casting numbers now, sorry blush
Re: 426 hemi dual plug heads p4120960 [Re: dart games] #2730537
01/06/20 01:17 PM
01/06/20 01:17 PM
hemi-itis Offline
hemi-itis  Offline
I was able to port the large header flange to make them work.The exaust port only uses half of the port on the flanges.They also showed a little daylight on the top of the port flang requiring adding some material on the exterior top of the tube to flange. Not sure if it effects my performance but I have to work with what I have. As much as I would like a new set of headers it's just not in the very limited budget.
I do have an issue getting the flanges to seal well on the heads.
Re: 426 hemi dual plug heads p4120960 [Re: Cab_Burge] #2730789
01/07/20 01:16 PM
01/07/20 01:16 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
The D-4 heads were cast iron, raised exhaust port and for NASCAR racing. I think the nitro monkeys used them in the 1970s as well.
Floyd Lippencott IV
Re: 426 hemi dual plug heads p4120960 [Re: mr_340] #2730902
01/07/20 08:00 PM
01/07/20 08:00 PM
I was told by the owner that they where D-4 heads confused, They were aluminum and had a raised exhaust port that was about half the size of a street hemi exhaust port. I wonder if they could have been the later D6 heads for Pro Stock? confused His family owned several Chrysler, Dodge and Plymouth dealer ships in SO CA in the 1960s up to 2000 or so shruggy
I got lucky to be picked to assemble and dyno test that motor wrench grin
Re: 426 hemi dual plug heads p4120960 [Re: Cab_Burge] #2730952
01/07/20 10:50 PM
01/07/20 10:50 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Could have been D-6's. They look like D-4's but are aluminum and have twin plugs. Or they could have been Darts like you first spoke of, that had been ported to D-4 specs. That was a popular exhaust port at the time.
