Brake bleeder
#2729911
01/04/20 10:42 AM
01/04/20 10:42 AM
Posts: 1,487 STL
cdstl
STL
I bought a Motive Products brake bleeder. It's for modern cars with the twist on master cylinder cap. It's like a small weed sprayer where you put the brake fluid in it and then pump it up.
Has anyone had any luck with adapting a master cylinder cover so that we can bleed the brakes on our Mopars?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Brake bleeder
[Re: Sniper]
#2729934
01/04/20 11:53 AM
01/04/20 11:53 AM
Posts: 4,920 new berlin wisconsin
Mr T2U
i haven't used a motive bleeder on a older car. i own one, it works excellent. i have used it when upgrading at least 20 s197 mustangs to big front and rear calipers with braided lines. including my own.
perception is 90% of reality
Re: Brake bleeder
[Re: earlymopar]
#2729955
01/04/20 12:52 PM
01/04/20 12:52 PM
RapidRobert
and added a Schrader valve. Worked great. O'reillys has a good brass one for less than $3. (I don't have the brand/# handy) but just ask em for a "tank valve". drill/tap for 1/8 NPT. EDIT "xtra seal" # 15-593
Re: Brake bleeder
[Re: njmopar]
#2730048
01/04/20 05:08 PM
01/04/20 05:08 PM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I have a Motive bleeder with that adapter plate. Works “ok”. You do have to tighten the heck out of it to build pressure. Best to wrap it in old towels in case if leaks. Luckily I am using silicone, else would have been a real mess. My experience as well.
Re: Brake bleeder
[Re: cdstl]
#2730114
01/04/20 09:47 PM
01/04/20 09:47 PM
Posts: 1,487 STL
cdstl
STL
Thanks,
After I bought it I realized that I could have bought one with different caps as well as the plate. I've heard that guys have had limited success with the plate.
It's still in the box so I could return it and pay a little more for the complete "kit".
