dash circuit board help
#2729802
01/03/20 08:49 PM
01/03/20 08:49 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
I am working on a 72 Dodge Dart and was taking the wiring harness off the back of the gauge cluster. Well 1/2 of the pins came off the board with the harness, any one know if someone repairs these things? I know you can get a new one but they are on back order and put up an add for a used one. Just wanted to see if there are any other options. I did try to solder them back but it didn't take. Thanks
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: dash circuit board help
[Re: Stroker Scamp]
#2729814
01/03/20 09:08 PM
01/03/20 09:08 PM
Posts: 21,824 Kirkland, Washington
Pacnorthcuda
I be never done it but I think it ps possible to epoxy the pin back on the board and just sold a jumper to it for the electrical connection.
I’ve repairs a lot of boards, just never a dash board with those pins.
[Re: Stroker Scamp]
#2729851
01/03/20 10:58 PM
01/03/20 10:58 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
The pins can be replaced with a Mulinex type plug but it will require cutting the old plug off.
Years ago I had the tool that swedges those type pins onto the PCB. The pins are not soldered on, just tightly swedged. Works fine till you fiddle with the connector. I have saved a few by taking a steel tube from a ink pin that fit snug over the pins. Then with the loose pin set in place on the PCB, use a center punch to re-swedge the pin to the board.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Stroker Scamp]
#2729887
01/04/20 06:12 AM
01/04/20 06:12 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
My pins never had came off like that but it become loosen from the PCB at the point I could remove it with my hand couple of them. I noticed had a problem because some light or guage came in and out moving the conector on back. I reinstalled, tried to spread out the teeth on back like factory made ( need to remove the PCB from housing of course ) the best I could and solded them to the track on front. No problem since that.
If pins remain still some loosen, you could ad some epoxy glue from backside after they are solded to the track in front. Pins are empty inside so some epoxy inside up to the back of the PCB should be enough.
[Re: Jim_Lusk]
#2729926
01/04/20 11:33 AM
01/04/20 11:33 AM
Posts: 19,406 north of coder
moparx
I have removed the part left in the board and inserting the pin through from the back side. Find a nail that will force the pin to be tight in the hole when forced into the pin. Then solder the pin to the board. Easy and cheap. i have done exactly this. i used a tiny finishing nail or a paneling nail to insert into the pin. this method works like a charm !
