Put E body carpet in a 68 Dart?? #2728004
12/29/19 02:18 PM
12/29/19 02:18 PM
Howell, Michigan
Hemidavey Offline OP
Howell, Michigan
I cut my floor to fit the Richmond 5 speed and using a E body 4 speed hump due to long length, has anyone tried to use E body carpet in a A body?
Thanks, Dave
Re: Put E body carpet in a 68 Dart?? [Re: Hemidavey] #2728342
12/30/19 04:21 PM
12/30/19 04:21 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
way different
5549 post on old board
Re: Put E body carpet in a 68 Dart?? [Re: Hemidavey] #2728959
01/01/20 01:19 PM
01/01/20 01:19 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
You might need to have the front carpet custom made or at least the factory a-body altered. A auto interior place should be able to help.
Re: Put E body carpet in a 68 Dart?? [Re: convx4] #2729597
01/03/20 10:13 AM
01/03/20 10:13 AM
Howell, Michigan
Howell, Michigan
Thanks for input. I may buy some and set in place , worst thing is I'll have to pay to return it. Its an odd combo that will work out well. Having the shifter moved back will be a big improvement. Its a pro tour car we are building at my shop attempting to make Power Tour in spring.
