Page 1 of 3 1 2 3
Which fuel injection??? #2729209
01/02/20 12:14 AM
01/02/20 12:14 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Mild 440 (basically a stock 440 Magnum), dual plane intake (no option here unless there's a single plane the same height as the factory iron), and iron manifolds. What's the best out there for this setup? My son is willing to spend the money for the distributor and all that it takes to work best. He's looking for turn key reliability and good performance.
Re: Which fuel injection??? [Re: Jim_Lusk] #2729215
01/02/20 12:51 AM
01/02/20 12:51 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Holley Sniper. I have installed a few different brands and they are the best for the money. I have never had any issues with running them on dual plane intakes. The Hyperspark ignition is nice, but not necessary if you want to save some coin.
The only Carbs I care about are under the hood!
Re: Which fuel injection??? [Re: Jim_Lusk] #2729217
01/02/20 12:56 AM
01/02/20 12:56 AM
AndyF Offline
AndyF  Offline
You can get a factory reconditioned Sniper for $799. That is what I'd recommend for your engine. If it was me I'd add the Hyperspark so you can control engine timing and if Tanks Inc. makes a drop in EFI gas tank I'd install that too.
https://www.holley.com/products/fue...refurbished_-_sniper_efi/parts/FR550-511
Re: Which fuel injection??? [Re: AndyF] #2729232
01/02/20 01:38 AM
01/02/20 01:38 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Yes, we are going with a Tanks Inc. tank. His tank and pickup were in bad shape when I pulled them out last year so he needs a new tank anyway. That's a great deal from Holley vs. Summit's price. Might try to get all the parts that they sell from them.
Re: Which fuel injection??? [Re: Jim_Lusk] #2729256
01/02/20 07:47 AM
01/02/20 07:47 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't have any experience with the throttle body EFI systems but if I were to buy one right now It would be the holley sniper. I follow lots of EFI stuff and for that application that is what I would do for sure. I would stay away from Fitech.
A friend of mine has a shop that has installed a few of the MSD Atomic EFI systems and they have had great luck with them as well.
68 Barracuda Formula S 340
Re: Which fuel injection??? [Re: Bad340fish] #2729262
01/02/20 08:27 AM
01/02/20 08:27 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I've installed/tune a FiTech and will be trying out a Sniper for my own truck. FiTech does work out great, but the controller and user interface leaves a lot to be desired.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Which fuel injection??? [Re: GoodysGotaCuda] #2729287
01/02/20 10:51 AM
01/02/20 10:51 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Another vote for the Sniper. Been on my car for two years now on a 512 and it's been great.
Re: Which fuel injection??? [Re: Jim_Lusk] #2729292
01/02/20 10:57 AM
01/02/20 10:57 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I've been looking at the Edelbrock RB injection set ups
If I still had a MOPAR street anything I would be going this route. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Which fuel injection??? [Re: Bad340fish] #2729317
01/02/20 12:33 PM
01/02/20 12:33 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I have a neighbor friend that has the MSD Atomic on an LS in his Chevelle. while it works fine, getting tech support for it has been a challenge. I guess there is a group that he belongs to on Facebook and they have managed to figure out most of the issues on their own. He really wants to switch over to Holley.
'63 Dodge 330
11.19 @ 121 mph
Re: Which fuel injection??? [Re: GY3] #2729323
01/02/20 12:59 PM
01/02/20 12:59 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Holley has owned MSD for awhile but I imagine the support is better for the products under the Holley name.
Re: Which fuel injection??? [Re: Bad340fish] #2729345
01/02/20 02:03 PM
01/02/20 02:03 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I to have done some MSD Atomic, very basic system, works great, IF I was to do a T body EFI it would be the Holley Terminator Stealth
Re: Which fuel injection??? [Re: W.I.N. Racing] #2729359
01/02/20 02:41 PM
01/02/20 02:41 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I was looking at that at one time also. I wonder what is limiting power to 550hp?
Injector size, throttle size, plenum size, runner length, volume, cross section?
All of the above? Could it be as simple as just needing bigger injectors?
Re: Which fuel injection??? [Re: GomangoCuda] #2729368
01/02/20 03:29 PM
01/02/20 03:29 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I went out and read reviews of the Holley Sniper 4-bbl and no one was happy with it. I have a friend with a FiTech and it turned out great but as previously mentioned, the interface and owner's manual leaves much to be desired. His is on a Ford FE and it took four (yes, four) hours on the phone with tech support to get it to work properly.
Re: Which fuel injection??? [Re: Jim_Lusk] #2729390
01/02/20 04:36 PM
01/02/20 04:36 PM
AndyF Offline
AndyF  Offline
Your son will be happy with the Sniper as long as he has a basic understanding of computers. You need to know how to move around in a file system to find files, copy files, load files, etc. If your son has a laptop computer then he will be super happy with the Sniper. He can buy an interface cable and hook up his laptop to the Sniper and super tune it. Can even tune it while driving down the freeway. The Sniper contains a very advanced EFI system but you have to buy the special cable to access it. The Super Snipers come with the cable but they cost more. For your car I'd buy the reconditioned unit then add the cable later if your son wants to hook up a laptop to access the other features.
Re: Which fuel injection??? [Re: GomangoCuda] #2729404
01/02/20 05:07 PM
01/02/20 05:07 PM
Byron, NY
Byron, NY
Yes bigger injectors HP to 800ish...thats what they told me back in June.
'60 Willys CJ5
Re: Which fuel injection??? [Re: Jim_Lusk] #2729414
01/02/20 05:44 PM
01/02/20 05:44 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I recently put a sniper xflow on my Satellite. Install went well. Only got to drive it once on Dec. 13th. before they began salting the roads around here. Locked the trusty old mopar perf. distributor and set it up to control timing too. So far so good. Gonna have to wait for spring to do much more with it.
Re: Which fuel injection??? [Re: W.I.N. Racing] #2729434
01/02/20 06:50 PM
01/02/20 06:50 PM
AndyF Offline
AndyF  Offline
Yes you can order the Edelbrock unit with the larger injectors to handle more power. The Edelbrock systems that I've used work okay but they are a black box. They don't have any data logging capability and you can't make many adjustments to the tune. If they work then great, if not then there isn't anything you can do about it.
Re: Which fuel injection??? [Re: 6PakBee] #2729453
01/02/20 08:06 PM
01/02/20 08:06 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
The success is heavily dependent on your ability to either A) Understand how EFI works B) Your desire to know about how EFI works. The systems are sold as "plug it in, fire it up and go". While they're quite good, they require tuning if you want it to drive like a new-ish car.
Understanding of IAC operation, how coolant temp effects fueling, rotor/timing phasing, acceleration enrichment, RFI/noise suppression, cold start enrichment, warm-up enrichment, etc. are all going to be necessary skills to execute the swap well. YouTube is loaded with helpful videos on this stuff, but one has to want to learn how to do it. A large portion of the TBI kit buyers simply don't want to do that.
My Father in Law is who I installed the FiTech kit for, he has pretty good carb knowledge but was initially clueless on EFI. Without someone knowing EFI around [me], I can see the process for him being very frustrating, which is where many people who write reviews online find themselves. That said, his truck has never ran better!
2020 RAM 1500
Re: Which fuel injection??? [Re: GoodysGotaCuda] #2729505
01/02/20 10:56 PM
01/02/20 10:56 PM
AndyF Offline
AndyF  Offline
Yes, I see this every day of the week on the Sniper forum. The people who are unhappy with EFI are typically people who don't have good computer skills. They don't understand how to debug computer issues so they get frustrated. I worked with a car builder a while back who was super frustrated with an EFI system. This guy has been building high quality street rods for 40 years but he didn't know how to find a file on a hard drive so he couldn't upgrade his firmware. The guy knows how to fabricate any part on a chassis but he was stumped when it came to upgrading the firmware on his EFI system. I went over there and it took me less than 30 seconds to find the file and do the upgrade. So there isn't anything wrong with the EFI systems, but there are a lot of hot rodders who haven't yet learned how to install, tune or debug them.
Re: Which fuel injection??? [Re: AndyF] #2729508
01/02/20 11:02 PM
01/02/20 11:02 PM
AndyF Offline
AndyF  Offline
Another thing I see a lot of is that when hot rodders put EFI on their car they then blame the EFI system for anything that goes wrong. I got called out to a local hot rod shop last week to help them get a EFI conversion sorted out. They were all upset that the Sniper was not working and asked me for some help. I show up and after fiddling around for a while I see that the throttle body wasn't bolted tight so they had a vacuum leak which was causing an issue with the idle speed. They fixed that and then I noticed that the throttle linkage wasn't properly adjusted so the throttle body wasn't getting full throttle. That was why the engine didn't have very much power. They also had the system wired wrong and they had a leak in the fuel line. There was nothing wrong with the EFI system, it was just a bunch of mechanical problems. Had they had a carb on there they would've found all those issues. Since it was EFI they just assumed that the EFI unit was bad. These are guys who have been building hot rods for 50+ years. They have build hundreds of cars so they know what they are doing but they weren't familiar with EFI so they just assumed it was causing all of the issues.
Page 1 of 3 1 2 3
