68 AVS - remove lead plugs?
#2729379
01/02/20 03:57 PM
01/02/20 03:57 PM
Posts: 701 Northern California
lilcuda
Northern California
I'm rebuilding my '68 AVS with the single air bleed adjuster and the two lead-plugged mixture screws. Should I remove the lead plugs or not? Engine is stock, but I live in California, so the gas is crummy. Thoughts?
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
Re: 68 AVS - remove lead plugs?
[Re: mattsmopars]
#2729384
01/02/20 04:10 PM
01/02/20 04:10 PM
lilcuda
Northern California
these are the two types of adjusting screws I was referring too. Found these quickly on ebay so not a correct to part number of your carb, but hopefully it helps explain my reply. Mine is like the one in the top photo. I know Scott. I was considering having him do the carb for me, but I didn't want a complete restoration on it, so I decided to do it myself.
[Re: lewtot184]
#2729519
01/02/20 11:38 PM
01/02/20 11:38 PM
Posts: 44 Youngstown
Vincenzo
Youngstown
When you get to the idle mixture screws, if they are frozen be patient. You may have to use heat with a penetrating oil on and off for a couple days. Because the alternative is drilling them out and can be tedious, especially the first couple times. The above post is correct in that the screw in the middle only trims air, and is good for maybe a full point AFR.
Woodruff Carburetor Specialties 330-799-9479
[Re: lewtot184]
#2729693
01/03/20 03:47 PM
01/03/20 03:47 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
removing the lead plugs at the bottom of the carb will expose the mixture screws. these are for gas mixture. the top left hand thread screw is for air only. it's kinda like an adjustable air bleed. the bottom mixture screws can noticeably improve idle quality. removing the top of the carb and taking out the two clusters will expose the emulsion tubes and idle jet (the small brass tube). enlarging the idle jet orifice, especially on automatic trans cars, along with working mixture screws can make a big improvement in idle and low speed engine operation. This is timely and helpful for me too, as I've been unhappy with idle performance on one of mine. When you talk about the idle jet, you mean just drilling out the end of the small tube? Recommendation on how much enlargement is needed? Thanks in advance!
Lead, follow or get the hell out of the way
[Re: peabodyracing]
#2729728
01/03/20 05:09 PM
01/03/20 05:09 PM
Posts: 3,916 usa
lewtot184
usa
removing the lead plugs at the bottom of the carb will expose the mixture screws. these are for gas mixture. the top left hand thread screw is for air only. it's kinda like an adjustable air bleed. the bottom mixture screws can noticeably improve idle quality. removing the top of the carb and taking out the two clusters will expose the emulsion tubes and idle jet (the small brass tube). enlarging the idle jet orifice, especially on automatic trans cars, along with working mixture screws can make a big improvement in idle and low speed engine operation. This is timely and helpful for me too, as I've been unhappy with idle performance on one of mine. When you talk about the idle jet, you mean just drilling out the end of the small tube? Recommendation on how much enlargement is needed? Thanks in advance! yep. drilling the small tube. generally automatic trans carbs have a .031" idle jet and manuals .035". I run .039" with a 4618avs. mine won't idle worth a crap at .031". you can start at .035" and go from there. I leave the idle air bleeds, bypass, and economizer alone. I also use the edelbrock mixture screws. they have a different tip that doesn't require backing out as far as the factory mixture screws. there are some carter afb/avs tuning tips from carter out there on the web.
[Re: lewtot184]
#2729766
01/03/20 07:29 PM
01/03/20 07:29 PM
peabodyracing
Minnesota
Just what I needed. I'm dangerous now! Thanks much!
[Re: lilcuda]
#2729778
01/03/20 08:09 PM
01/03/20 08:09 PM
lilcuda
Northern California
Having a heck of a time getting the last bit of one of the plugs out. The first one came right out with the second left-hand drill bit. It unscrewed the plug perfectly. I was able to easily remove that screw. The other one is being more difficult. The drill got a tiny bit off center and now I am slowly trying to get the last of the lead out. I can move the screw a little bit, but the threads still have remnants of lead in them.
Any ideas?
[Re: dragon slayer]
#2729786
01/03/20 08:31 PM
01/03/20 08:31 PM
Posts: 3,916 usa
lewtot184
usa
I would say be careful. One man's engine is different than another's. Once you open it up, you can't go back to smaller. So I would make sure everything else normally check for proper idle and cruise is checked first. you can go back. done it several times testing.
[Re: lilcuda]
#2729822
01/03/20 09:20 PM
01/03/20 09:20 PM
Posts: 6,221 nowhere
Sniper
nowhere
Any ideas?
A sharp angled pick will help you get the lead out o the threads.
[Re: Sniper]
#2729952
01/04/20 12:47 PM
01/04/20 12:47 PM
RapidRobert
A sharp angled pick will help you get the lead out o the threads. HF has a set of cheapies that have different angles that will likely work for you
[Re: dragon slayer]
#2730974
01/07/20 11:49 PM
01/07/20 11:49 PM
lilcuda
Northern California
A bottom tap may help clean much of it out. That's what I ended up using. Had to order it from Amazon.
