Which sb OD trans is an easy swap....
#2729278
01/02/20 09:36 AM
01/02/20 09:36 AM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
Spitballin' here. Should have paid more attention when others asked basically the same question. And of course, I don't seem to be able to use the right search words. What trans uses a simple on-off button for the OD and no electronics? A500 or 518? And would it live behind a 360 in a pick-up doing moderate towing? Thanks, Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Which sb OD trans is an easy swap....
[Re: mrob]
#2729281
01/02/20 10:13 AM
01/02/20 10:13 AM
I_bleed_MOPAR
Buford, GA
Thanks, the '88-'95 unit is the one I was thinking of. Do you have to activate the OD very time or can you simply leave the switch in the "ON" postion?
Tim
[Re: I_bleed_MOPAR]
#2729290
01/02/20 10:57 AM
01/02/20 10:57 AM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Tim If you leave it on the transmission will shift immediately into fourth gear as soon as it shifts into third. It will still down shift on its own with speed, but will not down shift with the kick down. Leaving it on effectively makes it a three speed with a non-functioning kick down. I don't think it does anything bad to the transmission itself. This is only for OD though. You cannot leave lock-up on if you have a model that does have it - that will do damage. Honestly though, a pressure switch and vacuum switch is all that you need to automate fourth gear. Add one more pressure for lock-up. It's not complicated at all.
[Re: MarkZ]
#2729294
01/02/20 10:59 AM
01/02/20 10:59 AM
I_bleed_MOPAR
Buford, GA
Thanks. Food for thought. Just thinking of a possible future project and how to do it. Tim
[Re: Sniper]
#2729313
01/02/20 12:09 PM
01/02/20 12:09 PM
I_bleed_MOPAR
Buford, GA
Thanks, Sniper. Tim
[Re: rbkt65]
#2729532
01/03/20 12:11 AM
01/03/20 12:11 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
CRT John Cope can fix you up
[Re: I_bleed_MOPAR]
#2730216
01/05/20 10:28 AM
01/05/20 10:28 AM
Posts: 1,111 Usa
A39Coronet
Usa
I'm actively looking into the 4l65 swap for my Gen3 Cuda because it's a small case design with OD and lockup. I don't know enough about it quite honestly to "sell" the idea to anyone else but it may be something to look into for you.
Because it's a GM trans, parts seem to be available, affordable, and you can buy supporting parts and pieces at Jegs/Summit
[Re: I_bleed_MOPAR]
#2730457
01/06/20 07:00 AM
01/06/20 07:00 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I put a 2002 A500 in my Charger behind a 1995 5.9 Magnum. I mounted two switches on the console. With 3.55 gears I did not need to switch them on until I hit the highway. It never bothered me
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: A39Coronet]
#2730513
01/06/20 12:21 PM
01/06/20 12:21 PM
MarkZ
Worthy
Worthy
Because it's a GM trans, parts seem to be available, affordable, and you can buy supporting parts and pieces at Jegs/Summit I can see this having upsides if the OP was inquiring about an OD automatic behind a big block, but seeing as how Mopar made transmissions that bolt right up to his small block it probably isn't worth it. When I stuck a 518 in my Fifth Ave behind a 360 I did it for under $1k. The aftermarket support isn't lacking either. Then again, if it doesn't require surgery to make it fit then toss everything I said right out the window.
[Re: dfsmopars]
#2730514
01/06/20 12:22 PM
01/06/20 12:22 PM
MarkZ
Worthy
Worthy
I put a 2002 A500 in my Charger behind a 1995 5.9 Magnum. I mounted two switches on the console. With 3.55 gears I did not need to switch them on until I hit the highway. It never bothered me Kind of defeats the purpose of having an automatic, doesn't it?
[Re: MarkZ]
#2730578
01/06/20 04:05 PM
01/06/20 04:05 PM
Posts: 2,254 IL
furious70
IL
I have an a500 behind the turbocharged 383 in my 70 Fury. Psi switches for OD @ 45pmh and lockup @60mph, 3.91's and 28" tires, I don't like to lug it around. In the C body no tunnel work, just a custom mount.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2730602
01/06/20 06:17 PM
01/06/20 06:17 PM
I_bleed_MOPAR
Buford, GA
Thanks for all the input. I just scored a Dakota QC 2wd, 5 spd. with no engine for a song. Durango is a little ragged after the 2 not-my-fault accidents & really miss having a truck. Engine & many of the parts from the Durango will live on in the Dakota. I think it will be a fun little ride. Reason I asked about a simple OD auto swap is if I get tired of rowing a stick. I'm not getting any younger & since we moved back closer to Atlanta traffic is a bear. Thanks again. Tim
[Re: volaredon]
#2731212
01/08/20 07:22 PM
01/08/20 07:22 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
I've been to Atlanta during rush hour many times. Let's just say I would rather slam my male member in a sliding glass door than drive through that everyday.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
