Re: Which sb OD trans is an easy swap.... [Re: Guitar Jones] #2731397
01/09/20 12:28 PM
01/09/20 12:28 PM
moparx Offline
moparx  Offline
the real question is, why are you standing at a see through sliding glass door with your male member hanging out in the first place ? shock
beer
Re: Which sb OD trans is an easy swap.... [Re: moparx] #2731498
01/09/20 05:26 PM
01/09/20 05:26 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Because someone wanted him to drive thru Atlanta
Re: Which sb OD trans is an easy swap.... [Re: Guitar Jones] #2731509
01/09/20 06:08 PM
01/09/20 06:08 PM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Originally Posted by Guitar Jones
I've been to Atlanta during rush hour many times. Let's just say I would rather slam my male member in a sliding glass door than drive through that everyday.
shock shocked
While I hate Atlanta traffic (even up here in the 'burbs), I don't think I would go that far, GJ. wink grin
Like I said, I ain't gettin' any younger and for the time being I still love rowin' a stick. But there may come a day.... wink
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2732277
01/11/20 09:41 PM
01/11/20 09:41 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Tim.....don't be surprised if you make up new cuss words when you go to put the trans cross member back in the Dak! That was one of the hardest chores I had when I rebuilt Susan's 4 door Dakota! rant
Re: Which sb OD trans is an easy swap.... [Re: JDMopar] #2732427
01/12/20 12:44 PM
01/12/20 12:44 PM
Buford, GA
Buford, GA
I think after 28 yrs. as a dealer tech, I have mastered and made up all available cuss words. Daughter and SIL were picking at me one day when one slipped out. I told them you definitely don't want to be around me working on a car that is giving me trouble. wink biggrin laugh2
Actually the trans is still in the truck. They just unbolted the engine and slid it out. up
Tim
'71 Charger 383/727
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2733746
01/16/20 08:52 PM
01/16/20 08:52 PM
JDMopar Offline
JDMopar  Offline
Our crossmember was such a tight fit between the frame rails....I think I could have left the bolts out, lol. After I finally got it started with a BFH, it wasn't too bad.
Re: Which sb OD trans is an easy swap.... [Re: roadrunninMark] #2733822
01/17/20 09:27 AM
01/17/20 09:27 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
If you're going to add the transmission why not just go for the overdrive and lock up. Unless you really need a performance converter and even that I think is available if you want to pay $$. Did a added od to a 76 d100... nice to drive!
Re: Which sb OD trans is an easy swap.... [Re: dfsmopars] #2735203
01/21/20 10:03 AM
01/21/20 10:03 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Originally Posted by dfsmopars
I put a 2002 A500 in my Charger behind a 1995 5.9 Magnum. I mounted two switches on the console. With 3.55 gears I did not need to switch them on until I hit the highway. It never bothered me
How did you do that with a fully electronic valve body? I thought the hydraulic valve body went away after the 1995 model year?
Re: Which sb OD trans is an easy swap.... [Re: volaredon] #2735499
01/22/20 08:13 AM
01/22/20 08:13 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
What various parts and mods would be a good idea to beef up a 1995 A500 to go behind a mostly stock 1995 Magnum 5.9 V8 ?
A500 2.75 front planetary is interesting to me because I wonder how a
2.75 planetary/ 2.76 diff
Would compare to my present
2.45 planetary/ 3.21 diff
Drivetrain.
Re: Which sb OD trans is an easy swap.... [Re: 360view] #2735515
01/22/20 09:35 AM
01/22/20 09:35 AM
moparx Offline
moparx  Offline
that is easy to figure out.
a 904 1st gear is 2.45 x 3.21 rear gear = 7.86 start out gearing.
A500 1st gear is 2.75 x 2.76 rear gear = 7.59 start out gearing.
just about what you have now for all practical purposes.
beer
Re: Which sb OD trans is an easy swap.... [Re: moparx] #2736280
01/24/20 08:14 PM
01/24/20 08:14 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
Or another way to think about it 2.76 x 2.75 / 2.45 = 3.098.
So 1st gear in the A500 with a 2.76 rear gear would be equivalent to having a roughly 3.10 gear and a 904. Which, as moparx said, is about the same as 3.21 behind a 904.
1958 Plymouth Suburban
Re: Which sb OD trans is an easy swap.... [Re: BlueGhost] #2736315
01/24/20 10:03 PM
01/24/20 10:03 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
No being up on swaps, new to this A500. Have 77, 79 Traildusters 4X4 I would like to put in an over drive. Thought only options were finding a 1991-1993 A518
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Which sb OD trans is an easy swap.... [Re: hulmule] #2736668
01/25/20 10:31 PM
01/25/20 10:31 PM
Buford, GA
Buford, GA
From what I understand, a 518 is basically a 727 w/ OD & is found from '88-'96. The '92-'96 are lock-up units. A 500 trans is basically a 904 w/ OD. If that's the case (and I'm hoping someone corrects me if I'm wrong wink ), I would probably go with the later 518 for a TrailDuster for the lock-up feature. up Several members made on the first page for suggestions of the kit to rig the up the OD & lock-up. beer
Tim
'71 Charger 383/727
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2736703
01/26/20 05:55 AM
01/26/20 05:55 AM
A727Tflite Online content
A727Tflite  Online Content
Lock up was available on both the large and small series overdrives.
You can turn a non-lockup unit into one using the correct valve body, pump, input shaft and converter.
Re: Which sb OD trans is an easy swap.... [Re: A727Tflite] #2736712
01/26/20 09:13 AM
01/26/20 09:13 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
i have a 91 d150 that is tbi 318. it has a non lockup 518. i will use it for a project but from what i have seen/heard, some guys with more hp want this trans because they can put their conv in it without spending big bucks for new conv. i d it by it having 2 pin connector not 3 pin. i have a friend that uses the patc kit and i have one on shelf for my next project. good piece.
