Which sb OD trans is an easy swap.... #2729278
01/02/20 09:36 AM
01/02/20 09:36 AM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
Spitballin' here. Should have paid more attention when others asked basically the same question. And of course, I don't seem to be able to use the right search words. spank
What trans uses a simple on-off button for the OD and no electronics? A500 or 518? And would it live behind a 360 in a pick-up doing moderate towing?
Thanks,
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2729279
01/02/20 09:49 AM
01/02/20 09:49 AM
Maryland
mrob Offline
mrob  Offline
Maryland
I'd say look for an early (1988-1995) hydraulically controlled A-518. You can wire the OD to engage with a switch or even engage automatically using pressure switches. Be aware that the non lockup units (1988-1992) are much easier to wire through a switch. You just need 1 switch to engage the OD unit. The later units (1992-1996) with the lock up converters would need 2 switches (one for OD, the other for the converter). That would be cumbersome to control with switches alone, so you really would need pressure switches and/or a timer for the lock up converter.
Re: Which sb OD trans is an easy swap.... [Re: mrob] #2729281
01/02/20 10:13 AM
01/02/20 10:13 AM
Buford, GA
Buford, GA
Thanks, the '88-'95 unit is the one I was thinking of. Do you have to activate the OD very time or can you simply leave the switch in the "ON" postion?
Tim
'71 Charger 383/727
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2729290
01/02/20 10:57 AM
01/02/20 10:57 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Tim
If you leave it on the transmission will shift immediately into fourth gear as soon as it shifts into third. It will still down shift on its own with speed, but will not down shift with the kick down. Leaving it on effectively makes it a three speed with a non-functioning kick down. I don't think it does anything bad to the transmission itself. This is only for OD though. You cannot leave lock-up on if you have a model that does have it - that will do damage.
Honestly though, a pressure switch and vacuum switch is all that you need to automate fourth gear. Add one more pressure for lock-up. It's not complicated at all.
Re: Which sb OD trans is an easy swap.... [Re: MarkZ] #2729294
01/02/20 10:59 AM
01/02/20 10:59 AM
Buford, GA
Buford, GA
Thanks. Food for thought. wink Just thinking of a possible future project and how to do it. up
Tim
'71 Charger 383/727
Re: Which sb OD trans is an easy swap.... [Re: MarkZ] #2729295
01/02/20 11:00 AM
01/02/20 11:00 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Everything you need plus instructions for it to work without driver input. Once it;s installed is handles the chore for you. $88 plus they are current running a 10% off deal.
https://transmissioncenter.net/shop...ere-for-727-to-46rh-swap-wiring-diagram/
Re: Which sb OD trans is an easy swap.... [Re: Sniper] #2729313
01/02/20 12:09 PM
01/02/20 12:09 PM
Buford, GA
Buford, GA
Thanks, Sniper. thumbs
Tim
'71 Charger 383/727
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2729476
01/02/20 09:20 PM
01/02/20 09:20 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
sniper is right. i have a friend that has a 5.2 and 518 in 37 chrysler. he put one of those kits on and simply loves it. so much so, that he ordered on for his 49 olymouth. now i am ordering one for my 85 d150 that i am putting a 5.9/518 combo in.
Re: Which sb OD trans is an easy swap.... [Re: rbkt65] #2729532
01/03/20 12:11 AM
01/03/20 12:11 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
CRT John Cope can fix you up
Re: Which sb OD trans is an easy swap.... [Re: CSK] #2730108
01/04/20 09:09 PM
01/04/20 09:09 PM
GA
roadrunninMark Offline
GA
RB, what did your friend select for the "speeds" for the OD and lockup? I am thinking of going with "44" for OD and"50" for lockup. Mine will be a 42RH behind a built up 318, want to use 3.55 gears in an ebody.
Re: Which sb OD trans is an easy swap.... [Re: roadrunninMark] #2730123
01/04/20 10:17 PM
01/04/20 10:17 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
he went with 44 and 50 that patc lets you choose when picking speeds. but he also ordered an adjustable one for 49 for extra monies.
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2730216
01/05/20 10:28 AM
01/05/20 10:28 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I'm actively looking into the 4l65 swap for my Gen3 Cuda because it's a small case design with OD and lockup. I don't know enough about it quite honestly to "sell" the idea to anyone else but it may be something to look into for you.
Because it's a GM trans, parts seem to be available, affordable, and you can buy supporting parts and pieces at Jegs/Summit
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2730457
01/06/20 07:00 AM
01/06/20 07:00 AM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I put a 2002 A500 in my Charger behind a 1995 5.9 Magnum. I mounted two switches on the console. With 3.55 gears I did not need to switch them on until I hit the highway. It never bothered me
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Which sb OD trans is an easy swap.... [Re: A39Coronet] #2730513
01/06/20 12:21 PM
01/06/20 12:21 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I can see this having upsides if the OP was inquiring about an OD automatic behind a big block, but seeing as how Mopar made transmissions that bolt right up to his small block it probably isn't worth it. When I stuck a 518 in my Fifth Ave behind a 360 I did it for under $1k. The aftermarket support isn't lacking either.
Then again, if it doesn't require surgery to make it fit then toss everything I said right out the window.
Re: Which sb OD trans is an easy swap.... [Re: dfsmopars] #2730514
01/06/20 12:22 PM
01/06/20 12:22 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Kind of defeats the purpose of having an automatic, doesn't it? whistling shruggy
Re: Which sb OD trans is an easy swap.... [Re: MarkZ] #2730578
01/06/20 04:05 PM
01/06/20 04:05 PM
IL
furious70 Offline
furious70  Offline
IL
I have an a500 behind the turbocharged 383 in my 70 Fury. Psi switches for OD @ 45pmh and lockup @60mph, 3.91's and 28" tires, I don't like to lug it around. In the C body no tunnel work, just a custom mount.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Which sb OD trans is an easy swap.... [Re: furious70] #2730602
01/06/20 06:17 PM
01/06/20 06:17 PM
Buford, GA
Buford, GA
Thanks for all the input. up I just scored a Dakota QC 2wd, 5 spd. with no engine for a song. Durango is a little ragged after the 2 not-my-fault accidents & really miss having a truck. Engine & many of the parts from the Durango will live on in the Dakota. I think it will be a fun little ride. Reason I asked about a simple OD auto swap is if I get tired of rowing a stick. I'm not getting any younger & since we moved back closer to Atlanta traffic is a bear. frown
Thanks again.
Tim
'71 Charger 383/727
Re: Which sb OD trans is an easy swap.... [Re: I_bleed_MOPAR] #2730986
01/08/20 12:48 AM
01/08/20 12:48 AM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Since the A 500 is based on the later 904, it should have the 2.75 low first gear. That would help staring when pulling a load.
Re: Which sb OD trans is an easy swap.... [Re: Jjs72D] #2731107
01/08/20 02:36 PM
01/08/20 02:36 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
A 500 or a 518 will directly swap with each other without driveshaft swaps, etc. Same exact OD housing used on either one. Unlike a swap between a 904 and 727, these OD transmissions are the same overall length. I've put 518 (46RH) in place of 500 (42/44RH) a couple of times now. I'd go with the heavier duty trans of them every time.
But then I live 2 county's south of Chicago, among corrnfields, avoid Chicago like the plague anyway, and with all else being equal I'd rather row gears any time I can. Though I've been hurt badly twice over the years (right knee and then the ankle several years later) and both times the DR saying whether I could drive depended on whether my ride was auto or stick... Both times I had stick equipped vehicles so had to borrow vehicles or be chauffered around.
But yeah I have heard that Atlanta is 10x worse to drive around in than Chicago which is plenty bad in its own right. I'll have to take the word on the street about Atlanta, never been there.
Re: Which sb OD trans is an easy swap.... [Re: volaredon] #2731212
01/08/20 07:22 PM
01/08/20 07:22 PM
Guitar Jones Offline
I've been to Atlanta during rush hour many times. Let's just say I would rather slam my male member in a sliding glass door than drive through that everyday.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
