sway bar suggestions for 69 charger
#2728908
01/01/20 11:24 AM
01/01/20 11:24 AM
Posts: 19,310 north of coder
moparx
what would be your suggestion for front and rear sway bars for a stock front suspension, +2" arch rear spring, 69 charger ? no other plans for suspension. RB/727 combo. 215-70 front, and 12.50 rear tires. no planned changes there as well. does 1 1/4 and 7/8 sound about right ? poly or rubber end links ? not going to autocross or top speed twisties. just reduce some body lean in the corners. TIA.
Re: sway bar suggestions for 69 charger
[Re: moparx]
#2729200
01/01/20 11:32 PM
01/01/20 11:32 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I've got a '65 big block, power steering, Satellite hardtop w 225/70 BFG T/A's on Ford 14x6.5 steelies all around. In front, I installed a 1-1/8" tubular bar. In back installed a 3/4" bar with +1-1/2" arch. Poly bushings on all the sway links. OEM rubber everywhere else. For shocks I chose Monroe Matics in front and Monroe Gas-Matics in rear, so the rear is slightly stiffer shocked. It behaves the way I like it.. Less understeer than stock, turns much flatter without adding harshness, so very streetable. Stays neutral, but ultimately oversteers at the limit, and the oversteer can be brought on w throttle. Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: moparx]
#2729348
01/02/20 02:10 PM
01/02/20 02:10 PM
Posts: 22,695 Bitopia
jcc
Bitopia
IMO, on our Mopars, its always best to pick/install a TB package first and road test, and THEN decide on a front swaybar if needed, and THEN decide on a rearbar to fix the wrong size front swaybar ,to regain balance. And note, NOBODY has yet reported they picked to large of a TB. ( Ok, I'm sure somebody has, but in most cases, most wonder if they went big enough after installing, but everybody is at least partially happier with any bigger TB)
[Re: moparx]
#2729369
01/02/20 03:36 PM
01/02/20 03:36 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Bigger TBs would help with lean, dive, lift... and the sway bar would then be used a s a tuning device.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: moparx]
#2729416
01/02/20 05:49 PM
01/02/20 05:49 PM
67SATisfaction
Albany, NY
with the grease fitting in the brackets as well.
Yes, this is what my swaybar kits came with. Maybe they all do. I don't think the OEM setup is this way. I specifically chose to keep most of the suspension stock with a lot of OEM rubber to reduce harshness, since my '65 Satellite is primarily a street car. - Art
[Re: 67SATisfaction]
#2729636
01/03/20 12:47 PM
01/03/20 12:47 PM
jcc
Bitopia
If should be noted here any swaybar mounting induced "harshness" can only be transmitted into the chassis when that axles wheels are moving different directions/speeds vertically, ie a speed bump driven straight over will not cause any additional or less perceived "harshness" based on the swaybars chosen mounting configuration.
[Re: moparx]
#2729879
01/04/20 03:43 AM
01/04/20 03:43 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I really like the Hotchkis sway bars on my 68 Charger, the rear bar mounts with existing holes, VERY easy to install & is adjustable.
[Re: CSK]
#2730238
01/05/20 12:24 PM
01/05/20 12:24 PM
Posts: 1,374 Houston,Tx.
Lee446
Houston,Tx.
Switching to 1.03 TB's was the best first step I made on my B&E bodies, the difference in handling was great. On my 'Cuda I used the Hellwig 1.25 tubular front swaybar and the handling really improved! There was no downside, ride is smooth, body lean gone. The next major improvement you can make is a modern performance tire, T/A radials are not even close! Since I run 13" front discs, I had to go with a 17" rim, if you get a performance tire that is around 27" tall, 90% of folks don't realize it is a bigger wheel, It looks right. This is just my experience for a street driven, non-rally, muscle car.
[Re: jcc]
#2731606
01/09/20 10:30 PM
01/09/20 10:30 PM
67SATisfaction
Albany, NY
If should be noted here any swaybar mounting induced "harshness" can only be transmitted into the chassis when that axles wheels are moving different directions/speeds vertically, ie a speed bump driven straight over will not cause any additional or less perceived "harshness" based on the swaybars chosen mounting configuration. ..this is why it was my choice to use poly bushings on my sways, but kept OEM rubber everywhere else.. - A
