Spotting the difference between 360 & 340 Oil Pan
#2728569
12/31/19 03:10 PM
12/31/19 03:10 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I can spot the difference side by side, I own and have both installed ( but not easy to get to to measure), but if one comes across one at a swap meet, is there a single easy measurement one can take to verify which one it is, and what is the measurement for either or both? Make it easy to remember.
Re: Spotting the difference between 360 & 340 Oil Pan
[Re: a12rag]
#2728584
12/31/19 03:33 PM
12/31/19 03:33 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Uhhh, doesn't the 340 pan have a smaller diameter rear seal area ???? No The 360 have the smaller rear oil pan seal to the main seal holder All the rest of the LA motors,273,318 and 340 motors, have the bigger rear seal
[Re: Cab_Burge]
#2728593
12/31/19 03:49 PM
12/31/19 03:49 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
They are the same size both front and rear for 273, 318, 318 poly and 340. 360 is smaller at the rear only...if the ends are different it's a 360...
...FAFO...
[Re: skicker]
#2728625
12/31/19 05:40 PM
12/31/19 05:40 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
So from the rear bolt holes, the "LA's 273, 318, 340 have a short space to the drop down and the 360 has longer spaces. And all the 5.2 and 5.9 Magnum's use the old 360 type pans so long spaces for both.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: skicker]
#2728679
12/31/19 09:12 PM
12/31/19 09:12 PM
jcc
Bitopia
.if the ends are different it's a 360... Words of wisdom, and easy to remember
[Re: jcc]
#2728739
12/31/19 11:00 PM
12/31/19 11:00 PM
Dave_J
Auburn WA
Here is the difference between them.
[Re: Dave_J]
#2728989
01/01/20 02:19 PM
01/01/20 02:19 PM
RapidRobert
Good info! & on a side note there are several 360 pans that I have seen, a 392 & a 876 both of which has a sump ~8" long & the sump starts 4" from a plumb line straight down from the front lip on the 392 and 2" on the 876 & the 876 is needed for a 360 swap into an early A body and they use different pickups, the 392 pickup has a long sweeping bend & the 876 has a near right angle bend. there is a 360 van pan which has 2 indentations in the bottom on either side, not on the sump. #438. EDIT meant to say the 876 pan has the long sweeping curved bend pickup. MORE EDIT its the 392 needed on an early A 360 swap
