Spotting the difference between 360 & 340 Oil Pan #2728569
12/31/19 03:10 PM
12/31/19 03:10 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I can spot the difference side by side, I own and have both installed ( but not easy to get to to measure), but if one comes across one at a swap meet, is there a single easy measurement one can take to verify which one it is, and what is the measurement for either or both?
Make it easy to remember. biggrin
Re: Spotting the difference between 360 & 340 Oil Pan [Re: jcc] #2728570
12/31/19 03:12 PM
12/31/19 03:12 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Uhhh, doesn't the 340 pan have a smaller diameter rear seal area ????
Re: Spotting the difference between 360 & 340 Oil Pan [Re: a12rag] #2728584
12/31/19 03:33 PM
12/31/19 03:33 PM
No tsk
The 360 have the smaller rear oil pan seal to the main seal holder scope
All the rest of the LA motors,273,318 and 340 motors, have the bigger rear seal twocents
Re: Spotting the difference between 360 & 340 Oil Pan [Re: Cab_Burge] #2728593
12/31/19 03:49 PM
12/31/19 03:49 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
They are the same size both front and rear for 273, 318, 318 poly and 340.
360 is smaller at the rear only...if the ends are different it's a 360...
...FAFO...
Re: Spotting the difference between 360 & 340 Oil Pan [Re: skicker] #2728625
12/31/19 05:40 PM
12/31/19 05:40 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
So from the rear bolt holes, the "LA's 273, 318, 340 have a short space to the drop down and the 360 has longer spaces.
And all the 5.2 and 5.9 Magnum's use the old 360 type pans so long spaces for both.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Spotting the difference between 360 & 340 Oil Pan [Re: skicker] #2728679
12/31/19 09:12 PM
12/31/19 09:12 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Words of wisdom, and easy to remember up
Re: Spotting the difference between 360 & 340 Oil Pan [Re: jcc] #2728739
12/31/19 11:00 PM
12/31/19 11:00 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Here is the difference between them.
65 Formula S Cuda
Re: Spotting the difference between 360 & 340 Oil Pan [Re: Dave_J] #2728989
01/01/20 02:19 PM
01/01/20 02:19 PM
Good info! & on a side note there are several 360 pans that I have seen, a 392 & a 876 both of which has a sump ~8" long & the sump starts 4" from a plumb line straight down from the front lip on the 392 and 2" on the 876 & the 876 is needed for a 360 swap into an early A body and they use different pickups, the 392 pickup has a long sweeping bend & the 876 has a near right angle bend. there is a 360 van pan which has 2 indentations in the bottom on either side, not on the sump. #438. EDIT meant to say the 876 pan has the long sweeping curved bend pickup. MORE EDIT its the 392 needed on an early A 360 swap
